Spinner hole too big
UT
Hey guys, any thoughts or techniques out there for a spinner back plate prop bolt hole that was drilled for a larger engine and is now being mounted on a smaller engine? (besides changing the engine [])
It is an aluminum spinner and it is now way out of balance when the engine is running, probably because I cant get it centered with the larger hole.
Thanks!
Thanks!
UT
RE: Spinner hole too big
Yeah, this is a huge spinner P-40 and it was drilled by the previous owner, no bushing. Would be nice to have one. I have a bunch of bushings for smaller spinners but they arent big enough for this engine.
UT
need to fly today so didnt have time to do the machinist. Thought about it all night and this morning used a wheel collar that fit the hole then drilled the collar hole a little larger for the bolt. We'll see if it works. Dont have time to test it home on way to field.
