ESM T-6 Texan ii; 30cc DLE Engine Build
#52
#54
My DLE 35 has been flawless so far. I've got 20 flights on it with no engine issues at all. There are a couple other guys flying DLE 35 at my field and neither of them have had any issues either. There are a few guys flying DLE 30's that have had some dead sticks, but that's a completely different engine. The DLE 35 fits perfectly inside the cowl of this airframe.
#55
Yes, I know there's nothing wrong with the 35 RA.
The ones I mentioned are a buddy's that keep flaming out due to overheating in the tight closed cowl and/or flying it full throttle too early in the break in process.
Re-maidened yesterday after the engine-cowl mods, 3 flights - engine is cool at 100 C full throttle. Making good speed with a Metts 18x10 @ 7,000, I have to sort out an air leak in the retract system and then on to some serious scale aerobatics
#59
I would like to get one of these but I'm concerned about the retracts. Has anyone tried air retracts from robart or e-flite maybe for a b25? Also how does the DLE 35RA fit? How much of the cowl needs to be cut?
#60
SMK,
Keep away from the ESM electrics for the time being. Mine are ESM air up- air down made for the ESM B-25 and work well. The Robart tri-gear set for the TF Cessna-310 should fit too.
Erm ... so what up with the front gear in the above video?
At the field I noticed a leak in the air lines from the valve to the front retract so I did a quick fix by isolating the front gear from the rest of the air system and keeping it locked down.
