spitfire tail fin
RE: spitfire tail fin
ORIGINAL: suzonka
I have a 1/12th spitfire kit , the tail fin loks very small ,is this common on this model and will it not need to be made a bit larger ,the fin itself?
Good luck and enjoy your Spit.
Brad
My Feedback: (7)
ORIGINAL: Brad330l
suzonka, the tail section of early Mk Spitfires were actually quite small in area. Some models (RC) are reported to waggle their tails through tight turns and this would be because of this. Have a look at some scale drawings and compare the sizes. You have a 1/12th scale so you could blow up/ expand some drawings to see if there is much difference. By all means, make the tail a bit bigger. Some manufacturers do this to their models to get 'better' flying qualities out of them.
Brad
ORIGINAL: suzonka
Brad
I would appriciate it if you could send me a view of the tail section to my email [email protected]
ORIGINAL: Brad330l
Brad
ORIGINAL: suzonka
Brad
ORIGINAL: tdstaf
If its scale why would you change it? I've never had a problem using the scale outline. The real one flew with it.... Manufacturers only do it for inexperinced pilots.
ORIGINAL: Brad330l
Brad
ORIGINAL: suzonka
Brad
Brad
ORIGINAL: tdstaf
Brad,
I only ment that if it's small it's probably scale. And most manufacturers models are drawn incorrectly so they look wrong when they are drawn correctly. If it turns out to be scale he should just leave it.
Tim
Brad,
Tim
Suzonka, here is a 3 view drawing. Save and have a play in 'Paint' on your computer to get approximate size to compare outlines.
Be sure to report back! Also let us know what kit it is.
Cheers guys,
Brad
ORIGINAL: Brad330l
Tim no worries mate. I might have taken what you said a long the wrong line and I hope you know what I was meaning.
Cheers guys,
Brad
ORIGINAL: tdstaf
Brad,
Tim
Brad,
Tim
Cheers guys,
Brad
Yes, what kit is it?
