Air Retract Lube.
RE: Air Retract Lube.
ORIGINAL: BobH
I have a pair of Yellow Retracts in my YA Jug. They are second hand and older. One side sticks until "excersised" . Any one have a good recommendation for lubricant for the air cylinder "O" rings?
Thank you in advance.
The info on the back says: Manufactured for: Parker Seal, Lexington, KY . Ph 859-269-2351.
This may be the same stuff BVMsells.
Dash
My Feedback: (13)
air tool oil works great and it won't harm the rubber O rings or lines, rather it plumps up the rubber, I use the Senco brand 6$ for more than you can use in a lifetime http://www.cposenco.com/senco-pc0101...s-and-coatings
