H9 P-51 1.50 retract issues
IL
I have the stock spacers in the metal servo arm and using the 791 servers and the arm is jamming on the retract case. Has anyone seen this?
My Feedback: (8)
RE: H9 P-51 1.50 retract issues
Don't use the nut on the back side, just thread onto the aluminum arm adn tighten down with lock tight. You should also have the half cone spacer under the ball to set the ball off the arm. That will then position the ball to be in line with the retract arm.
