Wing MFG pro series F6F Hellcat
Help!!! I need to find a construction manual for a Wing MFG pro series Hellcat. I have everything except the manual. Foam wings are easy to do, but the Fuselage is gonna be a lot harder to guess what goes where and when.
If anyone out there has access to the manual (and a scanner?) I would sure appreciate it. I am sick and tired of ARF mainia and have had this kit for several (1997) years.
Thanks!!
CorsairCrazy
Thanks!!
CorsairCrazy
RE: Wing MFG pro series F6F Hellcat
I built the kit a few years ago but no longer have the manual. If Iremember correctly, legal disclaimer, the fuselage is built as a teepee. Mark the positions of the formers on the fuselage sides using the plans. Then, set the firewall on the building board and attach the fuselage sides to it, and build up from there in a teepee fashion using the former marks that you put on the sides.
-Brian
-Brian
