gear in byron p51 can i add oil??
NY
I bought q byron p51 and the air pressure now looks like it is dropping, can i add and oil or adative to the air system to help the problem ? I am also considering clipping all ends where they slip on to connectors in case of cracked ends inline ,,,
My Feedback: (28)
RE: gear in byron p51 can i add oil??
You can use some BVM Thin Lube. It is designed for retract and pneumatic components. This may get you in working order again.
http://shopbvmjets.com/zencart/index...products_id=25
