Ziroli Giant P-51 Linkage Selection Help Needed
NC
I'm in the process of building (scratch) the subject project. It has come the time to install the linkage but I'm not sure what is the best setup for this application. I do want to keep all the linkage internal to the airframe and control surface. Please advice on any linkage setups that are reliable.
Thanks for any advice,
Matt
NC
RE: Ziroli Giant P-51 Linkage Selection Help Needed
Hey Matt, Of course I read your post and understand you want internals. I have got 17 flights on a Ziroli P51 now that I finished in March. I went for ease and ease of maintenance so I went external with Ele. servo's in rear for the stiffness of that set up. How ever I would suggest Carbon fiber for it's rigidness and they have always been reliable for me Good Luck with your build and maybe I will run into you sometime with your Stang. Kevin.
NC
Kevin,
Real nice looking stang. AND I hope you don't run into me one day, but I would love to see yours fly. I was looking into the carbon rods for my use for the exact reason you mentioned, "rigidity". Other benifits like strength and light weight are two other desireable traits and will most likely go that route. Detail questions I have though is what size and what size, type, and manufacturer of attachments should I put in this plane. I still want to go internal and I think there is a means to accomplish that. If the real one had them, then so can the scale. You have a good reliable setup and eventually I may have to go your route. What parts did you use?
Matt
Matt
NC
Capt G,
Thanks for another great idea. I looked at your hanger and you have some very nice planes. How on earth do you find the time to build so many? Good on you! With the servo's in the stab how is the linkage to the elevators setup. I was thinking of putting the servo in the fuselage with a single connection to the elevators, somehow. That somehow is the big question I have and what components would be best suited for the job. Kevin had suggested carbon rods and I think that is the way to go also, but what size and what attachments to those rods are my concerns.
I do appreciate the feedback and believe me your suggestion has been a great help. I will evaluate if this is the right route for me and what I want to accomplish. Heck, I might crash and burn, BUT I have to give it a try.
Matt
Matt
NC
Hey Matt, I use 4/40 captured Hardware and Giant Scale horns. I like the type CF rod ends that are JBwelded into the CF rods, I then wrap the ends of the rods with sewing (sp) line and drop thin CA on that to combat any Fraying. So far not one single problem or failure. Many diff. makers are out there to supply these fittings just go with any quality maker that is readily available to you. Kevin.
NC
Just incase we never meet. My wife was doing the video so I want complain. Kevin http://www.youtube.com/watch?v=HLYGVrjFhHk
