Reload this Page >
ECOMRC Fokker D-VII
ECOMRC Fokker D-VII
Old 04-04-2013, 08:25 AM
  #101
BarracudaHockey
BarracudaHockey's Avatar
Default RE: ECOMRC Fokker D-VII
Looks like the weather is clearing out today so hopefully I can get out tomorrow so I don't have the usual peanut gallery thats always hovering over my review projects when I'm there on the weekends.
Old 04-04-2013, 08:30 AM
  #102
jstanton
My Feedback: (14)
jstanton's Avatar
Good I'll be looking for your flight report. Did you put in any down thrust on your engine?
Old 04-22-2013, 10:58 AM
  #103
jstanton
My Feedback: (14)
jstanton's Avatar
Andy,
Have you got any more flight on your Fokker. I hope to get out this weekend with mine. The rain here is finally starting to go away and our field is starting to dry out. I will give a flight report if I can fly the Fly the Foffker this weekend.
Old 04-22-2013, 11:55 AM
  #104
BarracudaHockey
I was having a problem with the motor, turned out to be a bad switch on the ignition line that was vibrating closed. The good thing is, it dead sticks ok LOL
Between weather and work I haven't been able to get back at it.
Old 06-17-2013, 04:54 AM
  #105
mr.magoo54
My Feedback: (45)
Has anyone been able to fly there planes yet.
Old 06-17-2013, 07:08 AM
  #106
BobH
You can adjust the stab incidence to help correct the climbing issue. That is sometimes done on the full scale Fokkers. Raise the front of the stab a bit, maybe a couple of degrees for starters. Then see how it flies.
Many full scale WWI planes require lots of forward stick to fly level. The wings generated a lot of lift. Of course the plus side was when attacked pulling back would result in a sharp evasive maneuver.
Old 06-17-2013, 07:23 AM
  #107
jstanton
My Feedback: (14)
jstanton's Avatar
I hope to fly mine this coming weekend. This will be the first flight since I corrected the upper wing incidence. If it still climbs I will try to adjust the stabilzer incidence some to correct for it. I'll post a flight report after the flight.
Old 06-23-2013, 05:19 PM
  #108
jstanton
My Feedback: (14)
jstanton's Avatar
Just got back from the field today and this is finally a great flying War Bird. The secret to this plane is to get the top wing incedance to -1.5 degrees and have the CG at 4.5" from the leading edge of the Top Wing. This plane flies like a big trainer and with a DLE-30 and a 19x8 prop this plane takes off very quickly and lands like your first trainer. I did not get any video today but I will fly it again this weekend and this time I will bring my video camera.
I know this has been a real job to get this plane right, but I am glad I stayed with it. This plane looks so good in the clear blue sky with a few white clouds around.
Old 07-02-2013, 07:25 AM
  #109
jstanton
My Feedback: (14)
jstanton's Avatar
Got 6 more flights on my Fokker last Saturday and this is becoming my favorite War Bird. Sorry still no video but I hope to get some soon. The take offs are a thing of bueaty and the landings have been all 3 pointers. The DLE-30 has more than enough power and I fly around at 1/4 throttle most of the time. Very nice rools and large loops
If you have this ECOMRC Fokker are planning on getting it please do not give up on it. Get yourself a wing incidence meter and get the Top Wing at -1.5 degrees. Also get the CG at 4.5 " from the leading edge and you'll have a wonderful flying WW1 War bird.
Old 07-15-2013, 01:47 AM
  #110
jstanton
My Feedback: (14)
jstanton's Avatar
I finally got the flight video of the Fokker D-VII. Sorry it took so long. It is a great flying War Bird so if you have one please don't give up on it. Stay with it and you'll really like the way it fly's.
http://www.youtube.com/watch?v=UyHyWDok9Ps
Old 07-15-2013, 06:09 AM
  #111
mr.magoo54
My Feedback: (45)
  Nice plane Jim, I haven't had the luck to fly my plane yet. I've been out to the field with it twice, and both times I had some kind of
problem with the engine or the wind picked up to much for me to feel comfortable with a maiden flight. I did want you said, and set
my incidents to 1 1/2- on the top wing, and the others are set at 0. I hope it fly's as good as yours. Thank you for your reports and
updates on the build of the plane. Its guys like you how make this Hobby well worth the time and money we put into are planes.
        Again I just wont to say WELL DONE & THANK YOU    Charlie
Old 07-15-2013, 07:03 AM
  #112
Lifer
Lifer's Avatar
I have the same engine in a Taylorcraft and it really runs well with a 20x6 wood prop. Thought you might like to know of an alternative.
Really nice plane!
Old 07-15-2013, 08:08 AM
  #113
jstanton
My Feedback: (14)
jstanton's Avatar
Mr. Magoo thanks for the nice comments. I would really like to see some video of your Fokker when you fly it. What engine did you go with?
Lifer,
I will consider the 20x6 prop if i ever break the 19x8 that is on the plane now.
Thanks Guys and flly well!
Old 07-15-2013, 12:48 PM
  #114
mr.magoo54
My Feedback: (45)
   Hey Jim, I went with the DLE-30 just like you, and ya I am going to take some videos of it on its maiden flight. Hope everything
turns out alright. Did you ever check your incidence on your engine. I put mine at 1 degrees starboard and 2 down.
Old 07-16-2013, 08:51 AM
  #115
jstanton
My Feedback: (14)
jstanton's Avatar
Mr Magoo,
Looking forward to seeing your video. To answer your question on the engine I did not do as you did. I just mounted it to the firewall but I did put add 2 degrees right thurst. I fell with the 1% down thrust you have on your engine you will not need very much down elevator to keep her flying striaght. I do have about 5 clicks of down evlvator on mine.
I had a 18x8 prop on the DLE-30 when I did the maiden flight but I find I like the 19x8 prop better. Just a little FYI
Old 07-16-2013, 09:56 AM
  #116
mr.magoo54
My Feedback: (45)
           Ya I got a 18-8  on it now, Ill see how it fly's like with that one on it first. I do have a 19-8 standing by thou. Thanks for the tip.
Old 08-14-2013, 05:35 PM
  #117
mr.magoo54
My Feedback: (45)
I finally got to fly my plane. It was a hand full to fly. It took all my down trim to get it to even be half way flyable. I got it on the ground without any damage, but it was way out of
trim. I set my plane up just as you all did. The only thing I can tell is that my incidents is off. How did you guys set up yours. I have the hanger 9 digital incident gauge. I did set
it up at 11/2 - incidents on the top wing and everything else was set at zero. Were did you (0) out your gauge at. I could use some help with this one.
Old 08-15-2013, 07:03 AM
  #118
BarracudaHockey
The lower wing should be 0 to the flat part of the fuselage with the canopy off.
The top wing should be - 1.5 to the bottom wing.
The landing gear spreader should be 0 to -1 from the main wing.
Its still going to climb, there's two high lift wings. You might also throw a washer under the top engine mounts to get a little down thrust
Old 09-01-2013, 07:40 PM
  #119
jstanton
My Feedback: (14)
jstanton's Avatar
Mr. Magoo54
Did you setup your wing incidence as Andy mentioned in his post. That is exactly how I did mine and it solved all of my climbing issues. Put you incidence meter on the bottom wing and set it up at 0 degrees. Then move it to the Top Wing and set it up at -1.5 degrees. You can then setup the little wing between the wheel at 0 to -1 degrees. If your plane is balanced at 4.5" it will fly pretty good with these setting. Good Look and let see your video when you get it done.
Old 09-02-2013, 04:46 AM
  #120
BarracudaHockey
Make sure the elevator connection is stiff
Old 09-03-2013, 07:37 PM
  #121
mr.magoo54
My Feedback: (45)
I had to reset my incidence. I set it up at the horizontal stab the first time, Big mistake. I set it up like you said and the plane fly's great now. I still have a lot of down elevator ( manually )
dialed into the plane thou. Is this the way it should be. The elevator connection is stiff. Thanks Guys for all your help. If I can ever find some one here with a good camera, I will post some pictures
Old 09-04-2013, 01:34 AM
  #122
jstanton
My Feedback: (14)
jstanton's Avatar
Sounds like you got it right now. I would really like to see your pic's and some video if you ever get someone to take it fir you.
Old 10-16-2013, 06:12 PM
  #123
jstanton
My Feedback: (14)
jstanton's Avatar
Mr Magoo,
Got any video or pic's of your Fokker Yet. I have been flying mine so much I think the guy's at the field think it is the only plane I have now.
Old 01-02-2014, 10:06 PM
  #124
deadstick79
deadstick79's Avatar
Hey All,
Glad i found this thread! Mine will be here next Thursday!
I'll be installing an Axi 4130/20 on a 6s8000mah pack! Guess I'll be adding a ton of weight to the nose ;(
Dan
Old 01-04-2014, 12:02 PM
  #125
jstanton
My Feedback: (14)
jstanton's Avatar
Dan,
Please post some pic's of your electric conversion of this plane. I would love to see how it turns out for you. Also remember to double check the wing incidence of the Top wing. Please use a wing incidence meter and make sure it is at a -1.5 degrees compared to the bottom wing. The best CG I found to be 4.5" from the leading edge of the top wing. Good Luck. It is a great flying War Bird and real pretty in the air.
Jim
