Reload this Page >
Ed's Ziroli B-25 Build
Old 02-24-2013, 05:57 AM
  #101
tevans55
Default RE: Ed's Ziroli B-25 Build
ORIGINAL: All Day Dan
bigE, great picture of the B-25 assemby line but where are all the workers? Dan.
May also be an inspection.
Old 02-24-2013, 08:57 AM
  #102
bigE
My Feedback: (25)
bigE's Avatar
Flap servo mount installed as well as framework for both aileron and flap servo access hatches. Aileron servo will be mounted to underside of hatch.
ID:	1855733   Click image for larger version
Old 02-24-2013, 11:04 AM
  #103
bigE
My Feedback: (25)
bigE's Avatar
And servo wire tubes installed. Just rolled up paper tubes.
Old 02-24-2013, 11:14 AM
  #104
georbeckha
My Feedback: (12)
georbeckha's Avatar
Nice progress bigE! I'm watching this thread closely as I have the 118" Ziroli B-25 I'm going to get started probably this year. (If I can find what box I packed the plans in when I moved a couple of years ago.) I got the 'Short Kit' as well as the Plastic/Fiberglass stuff Ziroli sells on his web site.
Keep up the great pictures and progress!
George
Old 02-24-2013, 11:44 AM
  #105
bigE
My Feedback: (25)
bigE's Avatar
Thanks George. I found some good threads on this build with the help of Termites dream (links are earlier on in this thread) that are helping immensely. Lots of good ideas out there.
Old 02-24-2013, 12:11 PM
  #106
bigE
My Feedback: (25)
bigE's Avatar
Prepping the wing skin for the bottom. I like to edge glue all the sheets together first to make a single skin using titebond 2. After the glue dries I sand the sheet to make sure it's perfectly smooth before installing.
Old 02-24-2013, 06:14 PM
  #107
bigE
My Feedback: (25)
bigE's Avatar
One more thing to do before sheeting was to figure out how I was going to hold the wing panel onto the center section. I went back and forth with the different ways to do it that I found looking through some other threads, but decided on something a little bit different. My approach has a single bolt that goes through a 1/4" ply plate that is attached to the outer wing spar, through a balsa and ply block that is glued to the center section wing tube guide, through the wing tube itself, and then through another balsa/ply block attached to the top of the wing tube guide and into a blind nut.
First pic shows how I used a scrap piece of tube with some sand paper attached to get the bottom balsa/ply to a nice snug fit.
I used a drill press to get a nice straight hole through the ply plate and into the wing tube.
After gluing the top and bottom balsa/ply blocks to the wing tube guide in the center section, I attached the panel to the center section tightly and continued the hole through those blocks.
Finally, added the blind nut and voila! Panel is tightly attached to the center section and with a rubber washer on the bolt, I feel positive that this will hold up just fine.
ID:	1855906   Click image for larger version
ID:	1855907   Click image for larger version
ID:	1855908   Click image for larger version
Old 02-24-2013, 08:20 PM
  #108
bigE
My Feedback: (25)
bigE's Avatar
Alright, last post of the weekend. I laid my wing skin over the plan, laid the panel over it, and traced the ribs onto the skin. With the 1/4" sq stick pinned to the plan in the right spot for washout, I laid a bead of titebond to the lines I traced and carefully set the panel on the skin and weighted it. I used CA to glue the flap and aileron ribs to the skin. Once dry I carefully curled the sheet at the wing tip and glued it in place. Everything appears to be nice and straight. I don't know why I was so worried about this part... Actually went pretty smooth once I figured out the best way to get the job done.
ID:	1856042   Click image for larger version
Old 02-24-2013, 09:08 PM
  #109
bigE
My Feedback: (25)
bigE's Avatar
Ok I lied. One more post. I'm really happy with how the bottom sheeting went on. And the panel is finally rigid and straight as an arrow. Also happy with how the curve at the wing tip came out. I was worried that the balsa would snap, but all is well. Now Comes the other side.
ID:	1856053   Click image for larger version
Old 02-28-2013, 12:39 PM
  #110
bigE
My Feedback: (25)
bigE's Avatar
I spent the last few nights working on the opposite wing panel. Now Both are sheeted on the bottom and ready to separate flaps and ailerons, but I'm going to hold off on that for a bit. Next up is work on the nacelles. (It's not letting me post pictures right now! Argh!)
Old 03-01-2013, 08:42 AM
  #111
bigE
My Feedback: (25)
bigE's Avatar
Can someone do me a favor and try posting a picture here? I keep getting an "internal server error" thanks!
Old 03-01-2013, 09:02 AM
  #112
georbeckha
My Feedback: (12)
georbeckha's Avatar
Same as you...
<fieldset>
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
</fieldset>
George
  #113
dondurrua
Old 03-01-2013, 09:03 AM
  #114
All Day Dan
All Day Dan's Avatar
You're not alone. We are all getting the "500" error. Dan.
Old 03-01-2013, 12:07 PM
  #115
bigE
My Feedback: (25)
bigE's Avatar
Thanks guys. I'll try doing it the old fashioned way for a while till it gets fixed. Here is the wing with the bottom sheeting installed.
And last night I started working on the nacelles. The two main formers that hold the retract mounting blocks went in first with epoxy.
Old 03-01-2013, 02:45 PM
  #116
Prekin
My Feedback: (19)
Prekin's Avatar
BigE. your are very fast!! How many airplanes you make per one year??
Have you already started with the fuselage or not?
Old 03-01-2013, 07:14 PM
  #117
bigE
My Feedback: (25)
bigE's Avatar
ORIGINAL: Prekin
Not as fast as I would like! I was doing ARF's for the last few years because I haven't had time to build. But I decided to make time this year.
I hope to start the fuse this weekend. I wanted to have the wing and tail partially complete or at least framed up before starting it- I think it will be nice to have them ready as it goes together. Stay tuned...
Old 03-01-2013, 10:46 PM
  #118
bigE
My Feedback: (25)
bigE's Avatar
More nacelle formers added. Any tips on "strip planking"??
Old 03-02-2013, 07:40 AM
  #119
RAMFlyer
My Feedback: (65)
Great thread with great pictures. This airplane is on my bucket list... Here is my contribution to this building thread: http://www.raysmodels.ca/Technical%2...ps%20index.htm
Go through the Technical Tips to the article on Strip Planking. Best one I have found in my library... Shows not only the proper way to strip the planks but also how to handle the strips as the spaces narrow.
Old 03-02-2013, 11:04 AM
  #120
All Day Dan
Ed, How did you upload the images "The old fashion way"? Dan.
Old 03-02-2013, 11:17 AM
  #121
bigE
My Feedback: (25)
bigE's Avatar
ORIGINAL: dondurrua
[img][/img]
Thanks Dad!!
Old 03-02-2013, 11:21 AM
  #122
bigE
My Feedback: (25)
bigE's Avatar
Ed, How did you upload the images ''The old fashion way''? Dan.
I uploaded the pictures to photobucket, and then it automatically gives you a link to cut and paste in the thread. Based on your previous advice I am making the pictures smaller. I like the big pictures, but I imagine they stink if takes forever to download.
Old 03-02-2013, 11:24 AM
  #123
bigE
My Feedback: (25)
bigE's Avatar
ORIGINAL: RAMFlyer
Thanks for that link! He makes it look easy- sounds like one of those things that seems intimidating but once you figure it out its not that bad at all. I'll find out soon enough...
Old 03-02-2013, 11:31 AM
  #124
bigE
My Feedback: (25)
bigE's Avatar
And another former.. Taking a bit more time than I planned on because I'm using Titebond on the Balsa/ply joints.
Old 03-02-2013, 12:32 PM
  #125
RAMFlyer
My Feedback: (65)
I've got my Me163 about half planked using that article for reference. Once you get a feel for it the planking moves right along but VERY tedious Stripping the planks out of balsa sheets also takes a long time... Always need way more than you think!
