Reload this Page >
Whats still available for the Nosen p51? rescued one today.
Old 04-08-2015, 06:09 AM
F4u5
My Feedback: (81)
Ah....homemade. Nice. I am too lazy for that....
JQ
Old 04-08-2015, 07:12 AM
Instructor
My Feedback: (16)
Instructor's Avatar
Hi Foodstick,
The Nosen P-51 flies real well. It is not hard to fly. Since you received one already built, you won't have any problems flying it. I have one with a Quadra 75 turning a Master Airscrew wooden prop that is 24X12. The planes weights 34 pounds and has Robart retracts. If left alone, the takeoff roll is about 30 feet. I always keep it on the ground for at least 60 to 70 feet before I lift it off. The CG is 1.5" ahead of former #6 according to the plans. I think I have mine about 1" ahead of former #6 and it flies real light on the controls. When you are ready to fly it, fly it like a War Bird and not like a 3D airplane. The control throws that I have are set up to these settings: Ailerons, 5/8" up and 1/2" down, elevator, 3/4" up and 3/4" down, flaps 45º down to land and it lands real slow. I always land mine on the main wheels, no three point. Rudder 1.5" left and right. Here is a photo of my plane. Enjoy your Nosen P-51.......
Larry/Instructor
Name:	Nosen P-51 Mustang.jpg
Old 04-08-2015, 12:23 PM
aghost
My Feedback: (13)
aghost's Avatar
Good work. Starting to look like a keeper.
Old 04-08-2015, 02:03 PM
foodstick
foodstick's Avatar
I wanted an aluminum heat shield to protect the motor box from the muffler heat...
My throttle setup needed to be setup to take heat due to the close muffler as well. So I think I have everything so it will work without making any radio interference.
Here is a shot of my partially constructed tail wheel steering setup...
ID:	2087248   Click image for larger version
ID:	2087257   Click image for larger version
Old 04-08-2015, 02:18 PM
foodstick
foodstick's Avatar
I even got some primer on the spinner.....
Old 04-08-2015, 02:33 PM
  #31
Instructor
My Feedback: (16)
Instructor's Avatar
I think I would set up some sort of override on that tail wheel steering linkage. Using a nylon gear servo, you might knock out a gear...
Larry/Instructor
Old 04-08-2015, 02:58 PM
  #32
foodstick
foodstick's Avatar
Larry I am right with you, that funny looking servo arm on the tail wheel servo is a (servo saver) with a self centering spring setup they use on rc cars, I am hoping its enough.
Old 04-09-2015, 05:27 AM
  #33
Instructor
My Feedback: (16)
Instructor's Avatar
Sorry about that , I didn't notice the funny looking servo arm. I'm sure it will work out just fine.....
Larry
Old 04-09-2015, 05:28 AM
  #34
mikes68charger
My Feedback: (34)
Cool project dont stop now.
Old 04-09-2015, 06:19 AM
  #35
foodstick
foodstick's Avatar
No problem Larry I am glad to have you keeping an eye on me, sometimes I overlook things
I will probably install a better servo as well. I am still in the mock up stage on the steering setup. I need to make some covers for the servo area also.
Old 04-12-2015, 08:08 AM
  #36
SIX GUNS
SIX GUNS's Avatar
foodstick are you going to have it ready for owatonna this year ????
Old 04-12-2015, 09:52 AM
  #37
foodstick
foodstick's Avatar
Ready for Owatonna, and flying at Owatonna are two different things ! hahahahahha
I admit I am more of a small low pressure event guy myself... With tons of people and commotion I don't enjoy flying much..
I have been messing with the plane a bit this morning, I keep finding things I need to do. The latest realization is that I am probably going to have to cut my lower cowl for clearence on the muffler, or wait until it gets heat damage.... its CLOSE, I could build a blister onto it for clearance... I started figuring out where the onboard kill switch is going to be mounted, and ran my wires back to the elevator and rudder servos...
Does anyone know if Nosen P51 tends to need a bunch of lead? I would guess it might .. I haven't really seen that discussed much anywhere.
Old 04-12-2015, 04:26 PM
  #38
IFLYRC-RCU
My Feedback: (28)
I have a Q 100 in mine.. no nose weight. That looks to be a G 62? you may have to add a bit of nose weight. Will not matter, I remember seeing these fly with Q 35s in the old days.....
Good luck, keep us posted. You will like the way the plane flies.
Old 04-12-2015, 05:38 PM
  #39
radfordc
My Feedback: (14)
radfordc's Avatar
The original Nosen design called for a .60 glow engine using a belt reduction drive. Can you imagine?
Old 04-12-2015, 07:51 PM
  #40
foodstick
foodstick's Avatar
hahahah, you mean like this?
Name:	belt reduction 1 sm.jpg
ID:	2088522   Click image for larger version
Name:	belt reduction 2 sm.jpg
ID:	2088523   Click image for larger version
Name:	belt reduction 3 sm.jpg
ID:	2088524   Click image for larger version
Name:	belt reduction 4 sm.jpg
Old 04-13-2015, 05:03 AM
  #41
radfordc
My Feedback: (14)
radfordc's Avatar
Yep, just like that!
Name:	Du-Bro thrust unit. 001.jpg
ID:	2088629   Click image for larger version
Name:	Du-Bro thrust unit. 002.jpg
Old 04-13-2015, 06:49 AM
  #42
foodstick
foodstick's Avatar
I did not even realize it was made by Dubro .....
Old 06-08-2015, 05:36 PM
  #43
foodstick
foodstick's Avatar
Slowly getting small things done on the Mustang...Found out I have some flap interference, had to do some reshaping of the inner flap edges...
Old 09-19-2016, 04:52 AM
  #44
Jonson341
I have 2 old bud Nosen airplanes finished. They both have Sachs in them. I wonder if they are the same airplanes lol
Old 09-19-2016, 04:25 PM
  #45
foodstick
foodstick's Avatar
Mine just needs some balancing and other small things done. I just haven't gotten around to flying it yet...
