EASYTIGER LA-7
#78
RE: EASYTIGER LA-7
hey casey u been quite busy thats good family first. here is a pic of what my harness looks like , u gonna need a good amount of HV connectors the choice is yours whatever you are comfortable with, there's not too many people that make these except hobbyking and eflite the connectors are really large for the hi amp batteries. the first two pics shows the series harness that goes between the arming/momentary switch via the ESC i soldered a 1watt 51 oms resistor to the red wire coming from the esc connected to a momentary switch this alows me to charge the hot end to elimanate the spark trough the arming plug u can get these fom rcacceories.com i use the 10agw the other end from the momentary switch must be connect to the red of the series connector or it will not work u must do it that way some controllers like genace has theirs built into the system so it less wiring to do the second pic shows the parallel connectors for the four batteries 10 amps, long flight times if u use the a-spec u can fly even longer, but they cost 10% more.i can make the harness for u if u need one just let me know what connector u going to use i ll make it i have access to good resistor here on the job i get them from an engineere here .
#79
RE: EASYTIGER LA-7
hey bubba no need to worry abou your comments were all men here it totally understandable no harm done a recent view of a warbird even on youtube got be convinced that large electric are quit the performers. theres reduction drives that u can use ow to match your large warbird it larger scale props that my next step. especiall when u dont want that gas motor exposed http://www.youtube.com/watch?v=gnvbbLG8I08
#80
RE: EASYTIGER LA-7
if that video dont have u convinced i dont know what will those a huge warbirds and as we all know after u get to certain size it just pays to go gas . hey bubba dont u worry we gonna get u inducted u gonna love it.
#83
RE: EASYTIGER LA-7
Hahaha. Gonna have to pry my gas engines out of my cold dead hands. I must admit those planes are impressive. Think it's kinda like Mac vs pc. What ever system you started with you tend to keep going on. The initial investment in hardware And software....blah blah.
In might just explore the whole battery scene (mind you I do have 3 battery powered planes) for my giant war birds. I just might.....
#84
RE: EASYTIGER LA-7
Bubba, i always wanted to hear an electric warbird with a sound system installed, sounds like a really neat way to break the silence of an electric plane. I've seen them on you tube but I can't hear them on the internet maybe in person i could. See If they sounded authentic enough.
Neville, you got this build down to art work, sure would like to be at the field when it takes to the air.
#85
RE: EASYTIGER LA-7
I have heard some great sounding sound systems and some that stink. A lot of work is needed to make the sound broadcast at its best. Electric planes are not silent. Many guys have them at my field and there is decimate prop noise on the larger motors and props. Not the same as a gas engine and definately not in the orgasmic Moki category but not silent by any means.
#86
RE: EASYTIGER LA-7
hey straight if you are coming to Deleware i'll be there , look for a 109 and the la-7 youll find me, i'm not hard to find. If bubba was here i'd let him fly it , hes getting the spirit i see it coming the gremlins gonna grab yah electrons will rule.
#87
RE: EASYTIGER LA-7
casey look at post #10 you will see the way i made the harness for the parallel batteries im having a hard time pulling up this drawing may have to use adobe
#88
RE: EASYTIGER LA-7
hey bubba before u buy any thing for a big electric motor is important search the webb. you might find deal in other places i got my motor from leaders hobby there tons of online stores that may have a good deal. do some research so you don't spend a ton of cash. as for the batteries dont go cheap those turnigy and flightmaxx packs will work just fine we are not flying racers or hipowere composite jets it reall is not nesessary to have all that high c rating for those low kv motors the will produce lots of tork and that what u need .
#93
RE: EASYTIGER LA-7
while im waiting for my retracts, got some things done my electric geebee and 3W70 powerer Mr.Mulligan/me 109. the geebee suffered a crash and the lipos caught on fire im in the process of reparing the nose and cowl.
#97
RE: EASYTIGER LA-7
i have so many planes to build i dont know where to start got a budnosen p51 that i also have to build and a boeing f4b. ill try to get them all dont by winter
#99
RE: EASYTIGER LA-7
this poleyester filler is so easy to work with and feathers to a smooth edge great for plastic and fiberglass it somewhat flexible ulike bondo that cracks when it hardens.
