Reload this Page >
FW-190 D9 1/5 by fokkerc.com
Old 02-22-2015, 04:41 AM
  #251
fokke
fokke's Avatar
This is the model in1/4 with DLE 85 :
Old 02-22-2015, 05:00 AM
  #252
Joespeeder
Hey Fokke,
If Roto finishes this project it looks like the 130FSI might be a good fit??
Linky
The drawing shows 133mm center-line to top of the valve cover.
zoom....
Joe
Old 02-22-2015, 05:27 AM
  #253
fokke
fokke's Avatar
Hi Joe , will fit , but need to change the main engine box in the wood construction with 60mm bck , usual this is not so big problem . See the last picture .
Zenoah 62cc :
Zenoah 80 boxer :
Up view
And Roto 130 cc
Old 02-22-2015, 06:15 AM
  #254
Joespeeder
Hey Fokke,
As usual, you're way ahead of me !!!
Really cool.
Joe
Old 02-22-2015, 11:53 AM
  #255
proteus_X3
My Feedback: (16)
Rumen,
Nice don't forget about us 1/5 scale guys I'm think a Dle-55RA would work nicely, maybe a little high on the power side.I would love put a small twin in my Dora maybe a Rotor 50cc,but I dont think it would fit in the cowling without cutting the sides of the cowling.VVRC 40cc or Dle-40cc might work,but again I think it would be under powered. While I always Satio FS engines in glow ,I'm not crazy about there gas offerings . Which brings me too the Saito FG-57Tcc anybody use one? It's a little on the pricey side[$1049.99] ,20:1 mix ratio and non Walbo carb keps me away,but it would sound nice.... Cheers: Rich
Old 02-22-2015, 01:02 PM
  #256
fokke
fokke's Avatar
Rich , I can't forget he 1/5 cose after several days I will cut the Dora fuselage
Yes, I will check what gas engines will fit in the nose in 1/5 Dora but don't forget the Anton, there the cowl is biger so I think that for the 1/4 Anton8 150cc Moki
Old 02-22-2015, 01:13 PM
  #257
kwik
kwik's Avatar
The Saito FG 60 will probably be the most perfect engine for the 1/5 Dora.
Old 02-22-2015, 02:09 PM
  #258
Joespeeder
Hey Kwik,
The FG60 looks great. I just got an email from Ray English last night and he is working on my OS 320FF for the SiSt D9. It would be another option for the 1/5 Fokke D9 I bet.
I'm having the drain ports moved to run it with the carb on top to help with tank placement and any performance mods Ray may recommend. He is going to A/B test it against his personal 320FF. As I know more I'll post the results.
Joe
Old 02-22-2015, 04:00 PM
  #259
proteus_X3
My Feedback: (16)
Kwik ,
Absolutely on the Anton, not sure on this Dora,but if Horizon Hobby ever gets them in stock I will buy one for my Holmen FW190A at 220mm 8.6" DIA it's perfect fit.
Old 02-22-2015, 04:03 PM
  #260
ticketec
Don't forget the XYZ 53cc twin for the 1/5 scale options!
Old 02-22-2015, 04:59 PM
  #261
Chris Nicastro
Chris Nicastro's Avatar
Since all of those engines are so very slightly larger than the 1/4 scale nose what about increasing the scale to compensate? It would be great not to have any mods or interference between the head, valve cover or plug cap and the cowl.
That Roto three cylinder is going to really cool.
Old 02-22-2015, 05:10 PM
  #262
Dowmer
Dowmer's Avatar
Chris, the GT 80 Boxer fits without cutting. It's a good match. Evo built a D13 at 1/4 scale and it fit great.
Old 02-22-2015, 06:26 PM
  #263
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Evo used a BME111 or 116 with custom exhaust.
Old 02-22-2015, 06:46 PM
  #264
Dowmer
Dowmer's Avatar
Ah, my bad. That's right it was the BME and it all fit as I remember.
Old 02-22-2015, 08:17 PM
  #265
fw190d9
fw190d9's Avatar
BME 110 extreme. Fit great with the plugs angled towards the rear. About 1/8" clearance from the plug cap to the cowl flap on each side. And thats with the cowl flaps fully closed.
E.
ID:	2075565   Click image for larger version
Old 02-22-2015, 08:20 PM
  #266
Dowmer
Dowmer's Avatar
Thanks Evo. Beautiful bird
Old 02-22-2015, 08:25 PM
  #267
fw190d9
fw190d9's Avatar
The 110 is an awesome little motor. I even got one to fit in a 1/5th scale P47!
E.
Old 02-22-2015, 08:28 PM
  #268
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Nice..
Old 02-23-2015, 11:49 PM
  #269
fokke
fokke's Avatar
WOW, so many coments, great , thanks for the ideas
I can not to do these changes because it will lead to other many bigger problems and changes
So I made the changes in the fuselage , the longer vertical stab , longer tail front the stab. the long and thin nose , and today I send the files for cut
I made the wood cowl with idea to make from it plug for composite cowl . I made also angles of the two ribs front the vertical stab as on the real airplane, was a little difficult but now is ok
Old 02-24-2015, 12:42 PM
  #270
fokke
fokke's Avatar
Hi guys , OK this is it , I am ready with the D9 1/5 plans In the plans I put the realy great FW-190 D9 profil of Thiery Vallet and his Kameleon Profils
Old 02-24-2015, 01:39 PM
  #271
proteus_X3
My Feedback: (16)
Rumen,Looking good,say what is the 1/5 scale Dora cowling Dia in inches/mm and length od cowl from firewall to propeller black-plate? Cheers:Rich
Old 02-24-2015, 01:53 PM
  #272
fokke
fokke's Avatar
The cowl diameter is 221mm or 8.56"inch
Old 02-24-2015, 04:21 PM
  #273
proteus_X3
My Feedback: (16)
Excellent! ticketec was right
I would never buy the engine from HK,but I might be temped too buy from Octopusrc.com and then send it too Frank Bowman and have him look it over and replace the piston rings. If I stay with the standard 1/4 32 ME-8 spark plug cap to cap distance is 215mm[shoe horn fit] The engine on sale now http://octopusrc.com/shop/index.php?...product_id=308
Old 02-24-2015, 04:35 PM
  #274
Dowmer
Dowmer's Avatar
Rich, I agree the octopus rc option would be nice. I like that they let you upgrade and I've heard many people say they like their service. Ticketec has a HK version and it has run great for him. I will say that I've bought 50cc motors from HK in the past and have had great results but I know there are others that haven't. To each his own.
Old 02-24-2015, 05:07 PM
  #275
vertical grimmace
vertical grimmace's Avatar
Funny, HK is selling OS engines as well now.
