Reload this Page >
FW-190 D9 1/5 by fokkerc.com
Old 03-02-2016, 12:48 PM
  #526
schwalbe 1
thanks again for compliments , 25 years building models aircrafts is the best way to get skills !!! ; covering done with 30gr glass fabric but instead of résin i use G4 :quick light and easy for same result as époxy and result trusted from a long time ago ..........
pics : cooling provided for engine and a little mold done to give a better look to wheels
ID:	2150433   Click image for larger version
ID:	2150434   Click image for larger version
ID:	2150435   Click image for larger version
Old 03-05-2016, 11:46 AM
  #527
fokke
fokke's Avatar
Nice job !
Do you think that is a good idea to change the mayn plans with holes in the first ribs like yours ?
Old 03-10-2016, 12:31 PM
  #528
schwalbe 1
i don't know if it's a good idea to make cooling hole in front part as a lot of engines can fit in cowl
at this point with all radio and engine parts the model weight is 20 kg i think 1 or 2 kg will be needed for balance for a final weight ready to take off bellow 23 kg : correct for a 1/4 anton ,my sist is 25 kg ,my airworld was 21 kg
ID:	2151813   Click image for larger version
ID:	2151814   Click image for larger version
ID:	2151816   Click image for larger version
Old 03-13-2016, 12:56 AM
  #529
fokke
fokke's Avatar
Do you think that will need more weight in the nose , I think that the engine is enough for the balance .
Also , for me is interesting how you will make the front hole of the cowl , on the original there have a prop . I can talk with my Austrian friend who make on his 3D printer details for my Dora's , to make a new propeller detail for Anton as the Dora radiator .
Old 03-13-2016, 07:27 AM
  #530
proteus_X3
My Feedback: (16)
Schwable,
I have followed Rumen's build and recently your build and all I can say is Incredible build sir;if I only had half you skills.Cheers: Rich
Old 03-31-2016, 05:49 PM
  #531
schwalbe 1
Originally Posted by proteus_X3
Schwable,
Rich , thanks for compliments , charly
Old 03-31-2016, 05:59 PM
  #532
schwalbe 1
Hi Rumen
update : work on rivets in progress , hatches and panels done
spinner from fighteraces.com : very good looking spinner , perfect for the model
i will make rivets only on the upper side , it's unusual but this save time and rivets aren't visible in flight .....
ID:	2155326   Click image for larger version
ID:	2155327   Click image for larger version
Old 04-01-2016, 01:06 AM
  #533
fokke
fokke's Avatar
Now I see what was your idea for the rivets , the result is superb !
Oh yes, defenetly it is not visible in flight
I wait your progress with big interest!
Old 04-01-2016, 06:22 AM
  #534
proteus_X3
My Feedback: (16)
Charly,
Nice rivet job,are those laser cut vinyl rub-on like Chad Veich sells? http://www.rcgroups.com/forums/showthread.php?t=2516519
Old 04-01-2016, 07:03 AM
  #535
schwalbe 1
yes it's the same product but i make them by myself , i have a vinyl cutter : investment usefull to build semi scale model , rivets and all paint mask can be cut with my own requirements ...
Old 04-20-2016, 02:14 PM
  #536
schwalbe 1
Hi Rumen
FW is nearly complete , have to test engine soon , next step is balancing the plane
will do pics outdoor next week
flight will occur ................... when i ll be inspired , not now : too much problems , turbine engine broken last week and others planes need work on them to keep them flying
ID:	2158274   Click image for larger version
ID:	2158275   Click image for larger version
ID:	2158276   Click image for larger version
ID:	2158277   Click image for larger version
ID:	2158278   Click image for larger version
Old 04-20-2016, 02:36 PM
  #537
proteus_X3
My Feedback: (16)
Schwalbe,
Your Focke -Wulf 190A is simply Beautiful,excellent work,I'm looking forward to your maiden report. Cheers: Rich
Old 04-23-2016, 09:09 AM
  #538
fokke
fokke's Avatar
Fw-190A8/R-8 "Sturm" WrNr 681497 flown by Walter Wagner 5/JG-4 1944...
We wait the first fly , tel as more about the balance and the weight?
http://www.clubhyper.com/reference/luftcambg_5.htm
Old 04-23-2016, 11:09 AM
  #539
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Pretty awesome there Schwalbe1. One of the favorite schemes for sure. Love what you did with the wheels! Good luck on your maiden.
Old 04-23-2016, 03:48 PM
  #540
schwalbe 1
Thanks again for compliments , end of construction , now it's time to look if that thing can be called plane !!!! , here we have wind and rain .... i test the engine today , seem to run fine but test stopped by the weather ; at this point plane weight is 22.5kg with 1.5kg of ballast .... same balance point as my sist model ; for the wheels , if they can handle the weight it's the cheapest possible wheels for a semi scale FW !!!! 6.5$ pair to compare with 250$ for the glennis used on my 109 !!!! for the scheme it's difficult to find accurate source on german paints of the end of war so long time ago as i don't make competion model , i have decided : if i like the result it's ok for me even if not strictly scale
plane need cockpit , pilot , stencils , jettisonable tank ,and lower part of gear pants to be complete .........will do those détails after the first flight
now ..........wait begin for a sunny day with moderate wind line up field ...............
Old 04-28-2016, 08:45 AM
  #541
fokke
fokke's Avatar
I back to my old project composite D 9 13
Everything is almost ready for molding, the gunhood of D9 is ready and the cowl to
Old 05-05-2016, 11:19 AM
  #542
schwalbe 1
IT FLY !!!!
done today !!! , two flights , airplane in perfect condition
engine is more than enought and run ok , need tuning but no sign of overheating , plane fly ok , no trim needed ,too sensitive on elevator : will add 500gr in cowl , stall is violent (volontary tested ) but recovery easy and quick , try to retract gear on second flight but not enought pressure , due to heavy crosswind i choose grass strip on second landing
ID:	2161098   Click image for larger version
ID:	2161099   Click image for larger version
ID:	2161100   Click image for larger version
ID:	2161101   Click image for larger version
ID:	2161102   Click image for larger version
ID:	2161103   Click image for larger version
ID:	2161104   Click image for larger version
Old 05-05-2016, 11:41 AM
  #543
tfarmer96
tfarmer96's Avatar
Well done Sir! Very nice bird!
Old 05-05-2016, 11:49 AM
  #544
fokke
fokke's Avatar
Charly.................... CONGRATULATIONS MAN !!!!!!!
I am sooooo happy that you made a realy great airplane , you can not imagine how I am happy about that !!
Tell as more about the fly and the landing, what was the landing speed , how work the flaps, , you know that I made the wishout of the wing, , this twist need to give more stability on low speeds
Do you have a video of the maiden ???
BW < Fantastic pictures !!
CHEERS
Rumen
Old 05-05-2016, 12:28 PM
  #545
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Congrats Schwalbe1!! Where was you balance point, how much weight did you add and what we're the throws set to. She looks great in flight.
Old 05-05-2016, 01:55 PM
  #546
proteus_X3
My Feedback: (16)
Charley,
Congratulate on your successful maiden flight,She sure looks great.Cheers Rich
Old 05-05-2016, 02:05 PM
  #547
schwalbe 1
to tell more about the plane and the two flights
balance point is at 180 mm from leading edge (170 on my sist model ) will add 500 gr to the 1500gr already fitted in cowl to set balance point at 170 mm , 180 must be considered as rear limit : at 180mm model flight is secure but elevator is too much sensitive for comfort as it's not a 3D plane but an heavy warbird (i use to fly all kind of model from 3D ,jets, gliders ,old timers ......) elevator is set with 20°defflexion up and down (35/100 expo)
when stall was tested i put the the model in nose hight attitude with 1/3 throttle to see if the model haven't bad habbits in the worse situation , stall was violent but the recovery was immediate (like the full scale !!!)
landing speed isn't very hight , a little more than a p51 CARF ,same as 1/5 fw190 sist but it's a larger model
today flying condition weren't very good ,crosswind up to 30 km/h , so i must do other flights to see more about the plane
flaps were set at 40° defflexion , when were used 5 or 6 "clics" of down trim must be added
i think it's a good plane , not the easiest warbird to fly due to his hight wing loading but it is stable , controls were efficients ....in comparison i have a bf 109 fiberclassics (2.5m , 21 kg ) : 109 is very difficult to fly and awfull on ground , i'm confidend with the FW and haven't be worried during the landing ; if you keep the engine running there is no reason to have a problem with the FW
no change needed on plans it fly without need of trims
just bought inzpan cockpit and will add a pilot for the next flights (don't like ghosts planes )
sorry no video of the flights , hope to do some next time
ps: i think with a moki it's possible to save weight as with a radial the engine weight is in front of the cowl
Charly
Old 05-05-2016, 02:12 PM
  #548
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Did you get the kit Izpan or built up version. I went with the kit. The dash needed some modification to fit.
Old 05-05-2016, 02:14 PM
  #549
schwalbe 1
thanks for congrats
mission nearly completed , it's time to think to an other work !!!!!!
Old 05-05-2016, 02:25 PM
  #550
schwalbe 1
me too take the kit version as i know modification needed , measurements were done for dash during building and i remove wood parts to fit side panels
1 or 2 pics of the dash Inside cockpit welcome !!!
