FW-190 D9 1/5 by fokkerc.com
#79
BC, CANADA
Fantastic work Rumen ,as usual . You definitely need a scale functioning exhaust for this one https://www.youtube.com/watch?v=xFMPvrp_SDk Maybe I could build you one if you give me a deal on one of your kits I know I alreay posted this on your BF109 page .. perhaps I should remove that one . I wasn't aware you had this D9 build going ..
#82
BC, CANADA
Thanks coming from you that is a complement . I've subscribed to your awesome FW build , and if anything it looks even more amazing sofar than your BF109 ..
#83
The Bf-109 projekt is a great , here you can see my video
https://www.youtube.com/watch?v=Cnb_LGbyq78 I LOVE THIS AIRPLANE
I wander does anyone know what is the difference between FW-A8 -9 and FW-190 D wing ???? I cant find any information about differencees ( if have ) And other , the differences between Horisontal stab of A8 version and D9 ???
PS: I have some ideas .
Thanks in advance
Ceehs
Thanks in advance
Ceehs
#84
I don't believe there was any difference in the wing. Have to double check my books to be sure. But actually, I think Kurt was going for the whole enchilada with the Ta152, however because the extended wing wasn't ready yet and the modified fuselage/new engine was, the high brass pressed him into going with what he had as an interim solution. They desperately needed fighters (and pilots)!
#86
My Feedback: (23)
#88
Thanks guys, yes I know the differences between versions after D ( Dora)
I wanted to know about A version but I find all information, Have differences in engine( nose) section, vertical stab ( D is longer) several details around cockpit , the longer fuse , several details in the wings , especially around guns, some hoods, and little different canopy
#92
Yes I will make exhaust stacks for sure , about the blown canopy I don't know , baybe first I will make the latest version and then I will see, I have so much work ....
Regards
Regards
#93
Remember it is the Jumo stacks, not Mercedes Benz. As you can see from the picture, they are quite wide and prominent.
I am using the Sist D9 without stacks now, and it is a bit embarrasing ; You can see straight through the plane !!
#94
Jose have the blown canopy ( if I don't make mistake) for his Ta
D-9 and D-11 , D 13 are with Jumo , so I will make it
The Ta-152 have DB 603 G engine ( and Jumo 213 A-C) , but his sticks are to different
#97
Hi , I have a big progress with the A8 fuselage but I'll post only two pictures, when I finish all work I will post more
I wonder what skale to cut for the first time, I make wto variants of plan in 1/5 and 1/4 scale ?
