Reload this Page >
TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Old 10-28-2012, 12:07 PM
  #2976
MX240
MX240's Avatar
Default RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
ORIGINAL: Valve floater
Thanks Mx240.
I am in the process of repair now. Had some fracture cracks thoughout the inner sections of the wing. Wing is done now.
The thing that i noticed is that my mains do not lock in the up position. May have just noticed this. Only had 4 flights on used plane.This doesn`t seem important because when the pressure is around 80lbs they stay up nicely and are quite snug and should not fall open during flight. It locks down good for landing. I never let my pressure get down low. Is it that lock down landing position is most important? Do yall think i should worry about this. The worst it can do is drop open an little if i pull some serious G`s but i won`t.
Thoughts?
I am on forth Mustang and on every one of them I have had to trim/grind down the mounts on outside wood beam OR you can slide some washers under the inside retract mount. With the gear UP and locked you should have a little play while it is in the wheel well.
Old 10-28-2012, 06:38 PM
  #2977
Jyjkoz
My assembly is going smoothly so far..I just wanted some input on going with one servo for rudder and tail wheel or should I keep it two? Is there any advantages on either? Also has anyone used the CA hinges? Or should I go with pin hinges? And one last question I have is I am using a DA50r I had laying around with a slimline wrap around muffler and I mounted the engine tonight with the hopes that I woulnd have to spend the money for a new muffler or hack up the Cowl....Well I have to do one or the other and I dont want to destroy the cowl so who makes a muffler for the DA50 that will fit in the cowl will not fall apart?
Thanks for all the Help!!!
Old 10-29-2012, 03:05 AM
  #2978
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
J tec makes a great muffler that will fit completely iniside the cowling. Mine has been trouble free for 6 years and nearly 500 flights!
Old 10-29-2012, 04:50 AM
  #2979
Vintauri
My Feedback: (25)
Vintauri's Avatar
I have the Jtec on my DL50 and it's a perfect fit. All you need is to trim the cowl on the bottom for the cylinder head and the two pipes to exit nothing on the side needs to be cut.
Old 10-29-2012, 04:13 PM
  #2980
MX240
MX240's Avatar
Here is a heck of a u-tube video of a real chopper pilot lifting a P-51 model out of the top of a tree....nice
http://www.youtube.com/watch?v=ffEYq...e_gdata_player
Old 10-30-2012, 10:26 AM
  #2981
Leroy Gardner
The J-Tech muffler is the way to go, no cutting sides of cowl as it's made for in cowl install useing DA 50 or DLE 55, fits both, just let them know what engine and plane you have as it's custom made per application. www.j-techrc.com I posted pict's of install way back in thread but will do it again for the new guys, Leroy
Also found some paint that looks pretty good in cockpit, Rust-Oleum moss green at Home Depot. Google P-51 cockpits and you will find many colors used in them, green that is.
ID:	1816264   Click image for larger version
ID:	1816265   Click image for larger version
ID:	1816266   Click image for larger version
ID:	1816267   Click image for larger version
ID:	1816268   Click image for larger version
Old 11-07-2012, 07:05 PM
  #2982
flyingp51
I think i finely found you. in reply from my e_mail sorry took me a while to figuer out where you were. any way on the 24 oz tank i need to know the size of the fuel line you used for the filler on the deck nexst to the on off switch large or small and, is it 1 fuel line (gas) one from the engine to tank and 1 from tank to out side of fire wall hanging do youfallow? let me Know still working things out. Jim Thanks Leroy
Old 11-07-2012, 09:55 PM
  #2983
Leroy Gardner
Hi Jim, did'nt know you were looking for me, I'll see if I can answer your question. Filler is a Sullivan gas filler for a 2 line system. line size is 3/16" yellow gas silicon, same for vent.Fuel pick up line goes to one port on filler and the other side of filler goes to engine. An adaptor for the pump line ( included with filler ) pluges into the filler blocking off line to engine while filling the tank, it prevents flooding engine. For vent line make a loop that will set on top of tank, aluminum 3/16' works well for this as it bends better than brass, connect to tank with fuel line hose and same to line out bottom of chin block. Use brass for that and solder a tab on it to secure to back of fire wall with screw. I can see tank front top when filling and I try not to fill it to overflow and that keeps raw fuel off bottom of plane. On that dump line out of bottom cut a 45 degree angle on the side facing rear so it can't siphon fuel in the air. I hope that is the answer your looking for. Don't forget to fuel proof back of fire wall and the whole tank well.
Cheer's Leroy
I just got your e-mail, will check back here to see if you got this. As a reminded don't forget to get the gas fuel stopper assembly, should have the right size lines with it, you can double check fuel line fit on engine and use the circle clamps on the fittings from tank to engine. You will find that the lines fit the tubeing pretty tight.
Confirm you got this, Leroy
Old 11-08-2012, 08:39 AM
  #2984
andernamen
andernamen's Avatar
Robinson Helo. Pilot was crazy though getting that close just to retrieve an rc plane. It was cool though.
Old 11-16-2012, 07:31 AM
  #2985
Bdsbob
My Feedback: (20)
I smacked my beautiful Biela 4 bladed prop on the ground during my first takeoff run! Darn!
Here is a poor quality cell phone video of my P-51 with a ZDZ 80 swinging a XOAR 24X14.
http://www.youtube.com/watch?v=h345yWbj27U
What fun! I could and did this all day long!
Old 11-16-2012, 01:38 PM
  #2986
Doomking
My Feedback: (38)
Doomking's Avatar
Quick question.
When you glass the elevator and rudder, how do you keep the fabric from sagging since they are not sheeted, while you apply the finishing resin?
Thanks for the help.
Old 11-16-2012, 01:41 PM
  #2987
dasintex
My Feedback: (10)
dasintex's Avatar
Use Iron On Cloth like Coverlite
Old 11-16-2012, 02:06 PM
  #2988
BobH
In other words. dont glass the tail feathers. Unless they are metal (full scale) you want fabric.
Old 11-17-2012, 07:38 PM
  #2989
Valve floater
Well, Mustang back in action. After tossing the SV-50 and installing a DLE-55 it`s running great. Had to replace both main strut tubes, snapped in crash. Fixed busted wing holes on both sides where wheels punched through on dead stick landing. Removed mains and beefed up wing area that had stress cracks. Installing engine was a bear because the firewall location,standoff length and crankcase were all different. Did 4 flights and flies like it`s on rails. She wants to climb a little at times so a little down trim was need. But the down causes my take offs to go nose foward so i have to watch my prop and keep a little up as needed. On take offs, i have to apply a moderate amount of right rudder. Pulls to the left. Engine torque?
All air retracts. Is it normal for the mains when dropping to hit with a good amount of force when hitting the stop point and locking in? Seems like this puts a lot of stress on the robart frame and wing. Wheels up is realistic and slow. Anyone make a stop cushion?
Old 11-18-2012, 02:56 AM
  #2990
Doomking
My Feedback: (38)
Doomking's Avatar
If you are using a Robart variable rate air valve you can turn the screw in and slow down the struts when they come down.
Also if that is not sufficient, Robart offers air line restrictors that limit the amount of air going through the air line, thus making the strut move slower.
With the restrictors you have to locate wich line is up and down and of course installing them in the down one.
Hope this help a little.
Old 11-18-2012, 01:41 PM
  #2991
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
Valve floater, It's called P-factor. The blast off the prop swirls around the plane, so it hits the left side of the rudder more thus causing you to add right rudder to compensate.
Torque, rolls the plane oppisite of the rotation of the engine.
Hope this helps
Kelly
Old 11-18-2012, 04:16 PM
  #2992
spitfire66
spitfire66's Avatar
You will have several factors causing you to use rudder. If you are noticing more rudder in the climb here is why.
P-factor is the angle of the downward swinging blade having a greater angle of attack than the upward swinging blade. It will be exaggerated in the climb. Hold a prop level on the tip of a pencil and notice the angle difference between the two blades when viewed directly from the side. Then keep in mind where the wind will be coming from. Now tilt the pencil up (simulated climb) and compare those blade angles against each other to the relative wind it is about to disturb and notice the blade angle differences now.
spiraling slipstream is the air swirling to provide a force on the rudder
torque from the engine provides equal, but opposite reaction (newton's law). Prop goes to the right when viewed from the cockpit and wants to roll the plane left. Rudder corrects this back to the right (straight)
For those who are interested in the aerodynamics I hope you enjoy. I haven't been active on the forums for awhile and felt the need to post. I have too much going on right now to work on my p-51 and have been missing my hobby.
Old 11-18-2012, 06:41 PM
  #2993
Valve floater
Thanks guys. That makes sense on the pulling to the left on take off. I have other 50cc planes but i find the mustang to pull to the left more for some reason.
I have the red Robart adjustable valve. I noticed one side the needle is missing. On the side closest to the servo hookup on the plunger. Guessing this is the down adj. I will call Robart tomorrow and see if i can just get the needle. Thanks.
Old 12-01-2012, 10:51 AM
  #2994
Valve floater
Choke set up. Not done by me. Looks like it took some hard thinking but it works great.
ID:	1825523   Click image for larger version
Old 12-01-2012, 12:17 PM
  #2995
flyboy12
My Feedback: (57)
flyboy12's Avatar
As long as it works thats all that matters right? I have mine set up like that on my Wild Hare SU27
Old 12-01-2012, 04:52 PM
  #2996
Leroy Gardner
Default RE: Scale cockpit - Wow
ORIGINAL: FBaity
Darrell,
I am now to the point where I have to install the landing gear doors. I have input from you, Top Flite and others to use as referance. I have bought Robarts's DB670 door brackets which makes the strut attach easier. Still not sure if I want to hindge the upper part of the door or use two door brakets per strut and just attach to strut only.
Frank
Hi Frank, I'll try to help out here. First the mount is a weak spot and should be boxed in front and rear and glassed in, that will strenghten the rails and you can 30 min. epoxy the under side of rails to beef them up also. when you drill the mounting holes don't drill a to small a hole for the #6 screws as that really stresses the maple block and leads to fracture later on. Oops dinner time I'll finish this in a bit.
Another concern with Robart gear is that they are capable of supporting alot heavier plane, up to 35-40 lb's. and it's like having a stiff leg on a 15 lb. plane. I cut 5 full coils off the springs in the strut so they will give when landing instead of damaging the mount from the shock..
I built mine from the kit and it's a little different from the ARF and RTC but not different enough that the gear doors can't be mounted to leg stiff or hinged, depends on what you want it to look like. Here is mine, made from the kit balsa ply ones.
ID:	1825615   Click image for larger version
ID:	1825616   Click image for larger version
ID:	1825617   Click image for larger version
Old 12-01-2012, 05:01 PM
  #2997
speedbrake
speedbrake's Avatar
Has anyone installed a sliding canopy? Please share method used.
speedbrake
Old 12-01-2012, 08:35 PM
  #2998
Leroy Gardner
ORIGINAL: speedbrake
speedbrake
Hi speedbreak, would like a sliding canopy huh ?. I made mine from the kit bubble and it works and looks great. I'm not sure if you want to do it to a ARF or not but it can be done as you'll need to cut some no matter how you do it. See picts and let me know if you need more info.
It is manual operated and held with 2 small screws.
ID:	1825662   Click image for larger version
ID:	1825663   Click image for larger version
ID:	1825664   Click image for larger version
ID:	1825665   Click image for larger version
ID:	1825666   Click image for larger version
ID:	1825667   Click image for larger version
ID:	1825668   Click image for larger version
ID:	1825670   Click image for larger version
Old 12-01-2012, 09:54 PM
  #2999
Jyjkoz
For the DA 50 Should I get a 22X10 prop? Has anyone used the Xoar WWII props?
Old 12-02-2012, 07:05 PM
  #3000
Jyjkoz
