Anyone seen an easytiger stuka?
My Feedback: (73)
I've seen one at Warbirds over Delaware. Looks decent but pray you never need any service from them based on my experience. Several fellow flyers in my club have ET models and nothing but troubles getting the kits or replacement parts.
The Stuka Easytiger sells is made by a factory called CY Models in China. It is also distributed in Australia by Austars Model. I did a build and review for Austars Model for one of the prototypes. It flew well and the construction was relatively good. The main points were the cowl was far from scale (which has since been changed to the correct shape) and the non scale tailwheel as supplied for the test model (don't know if they have changed that) and the lack of elevator mass balance and shroud and the lower tail to fuselage support struts (easily added if you want to make a set). All these issues and some minor points were given as feedback to the factory so I don't know where they are with them. As a blank canvas for a scale model (the factory paint job on the prototype looks terrible to me) it has a lot of potential and at the same span as the Ziroli but with a two piece wing it saves a lot of building. Attached is a pic of the prototype flying (well) with a DLE-55RA, Beila 20x10 3 blade prop and a Ziroli spinner. If you want anymore info pm me. Cheers, Dave
Found some more pics of it, and a video:
http://www.youtube.com/watch?v=4_kPinviFqs
