Reload this Page >
SBD Dauntless by ESM
Old 04-08-2014, 10:06 AM
  #176
Prekin
My Feedback: (19)
Prekin's Avatar
Yes, a necessary part of many scale airplanes. I´m glad, I have possibility to do it in my job.
Old 04-14-2014, 09:49 AM
  #177
Prekin
My Feedback: (19)
Prekin's Avatar
I was looking for some good barrels for front machine guns, finally I decided to cast a scale machine guns.
ID:	1987009   Click image for larger version
ID:	1987010   Click image for larger version
Old 04-16-2014, 03:19 AM
  #178
OldScaleGuy
OldScaleGuy's Avatar
Prekin, this is interesting. Please explain the process.
Old 04-16-2014, 07:35 AM
  #179
Prekin
My Feedback: (19)
Prekin's Avatar
OK Steve.
At the first you have to make some frame. I made it from pieces of wood.The frame must be similar size as a model which you want to make. Also you can make a frame with botton.
At the second time you wax the model (M.G. in my case) and dip it into casting resin. After that you will wait than the resin going harden.
After some hour (time depends on the type of resin) you take out the model (machine gun) and form is done.
Now you can make (cast) your machine guns. You must wax the form before every use. You use a beeswax.
If you want to make only one copy, you can also use a modeling clay for a form.
Old 04-17-2014, 07:18 AM
  #180
Prekin
My Feedback: (19)
Prekin's Avatar
Finally I casted new machine guns. Here you can see the result. The form is made from two pieces.
ID:	1987668   Click image for larger version
Old 04-17-2014, 07:43 AM
  #181
OldScaleGuy
Thank you Prekin! Very interesting.
Old 04-17-2014, 09:44 AM
  #182
Prekin
My Feedback: (19)
Prekin's Avatar
Here are both of the machine guns. They are without handles. It would be too difficult make a form for the MGs with handles.
Old 04-19-2014, 10:17 AM
  #183
Prekin
My Feedback: (19)
Prekin's Avatar
Here is ammo belt from Williams Brothers. This ammo belt is 1/6, so it is little bit bigger, but I couldn´t find any one smaller. I think, that difference between scale of fuselage and ammo belt won´t so visible. I´m thinking if the belts should hang from the MGs free in space or the end of belt is somewhere other.
ID:	1988177   Click image for larger version
Old 04-19-2014, 11:10 PM
  #184
Prekin
My Feedback: (19)
Prekin's Avatar
End of ammo belt is in the box behind the gunner (in the way of flight). My opinion is based on following pictures. They are from books which I own.
ID:	1988347   Click image for larger version
ID:	1988348   Click image for larger version
Old 04-20-2014, 01:11 AM
  #185
Prekin
My Feedback: (19)
Prekin's Avatar
I made holes into machine guns and set them for ammo belts. In the pictures are not the belts glued, but they hang free in MGs. Probably I won´t lead them into ammo box, because the box is just glued and it would be too difficult make holes for ammo belts in this box. I should make them earlier.
ID:	1988364   Click image for larger version
ID:	1988365   Click image for larger version
ID:	1988366   Click image for larger version
Old 04-20-2014, 03:10 AM
  #186
OldScaleGuy
Nice work Prekin. Very good detail.
Old 04-20-2014, 03:19 AM
  #187
Prekin
My Feedback: (19)
Prekin's Avatar
Steve, without you wouldn´t have any ammo belt. So this is also your merit. So, thank you very much.
Old 04-20-2014, 05:11 AM
  #188
Prekin
My Feedback: (19)
Prekin's Avatar
I try to find which Japanese aircrafts were in battle of Gilbert islands but I´m not able to find any information. Does anybody know which Jap. aircrafts were there? I think, that on island Tarawa was Japanese airfield.
Old 04-21-2014, 04:03 AM
  #189
Prekin
My Feedback: (19)
Prekin's Avatar
Rear machine guns are completely done. Last morning I attached side shields and ammo belts, of course. Side shield I made from piece of plastic bar and glued a pin on the back. I made a hole in the machine gun for this pin and glued it.
When I was painting the shields, I also painted the barrels for the front machine guns.
ID:	1988617   Click image for larger version
ID:	1988618   Click image for larger version
ID:	1988619   Click image for larger version
Old 04-21-2014, 08:27 AM
  #190
OldScaleGuy
Glad to help!
Old 04-21-2014, 10:39 AM
  #191
glazier808
glazier808's Avatar
That looks great!
Casey
Old 04-21-2014, 10:44 AM
  #192
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you Casey. It would be nice to see your Zero behind my Dauntless in the air. Do you know, what kind of Japanese warbirds were on Gilberts islands during autumn 1943?
Old 04-21-2014, 11:08 AM
  #193
glazier808
glazier808's Avatar
I don't know specifically, but going by the given date, I would say you're probably likely to see
A6M3's, A6M5's, Ki84's
I'll have to do some research...
I'll get back with you if I find anything out
Casey
Old 04-21-2014, 11:29 AM
  #194
glazier808
glazier808's Avatar
http://www.tarawaontheweb.org/stanjersy1.htm
This is info about the history of the Gilbert Islands during the war as told from the Japanese side.
It's a little lengthy, but you can tell from the info, that the Japanese sent planes from Rabaul and the Marshall Islands to intercept the American forces. As the Gilbert Islands were a sea plane base, you may have seen some of their floatplanes based from there. You're most likely to encounter just about anything that the Japanese had it seems like. Both their Army and Navy aviators could have been involved.
Good question!
Casey
Old 04-21-2014, 11:40 AM
  #195
Prekin
My Feedback: (19)
Prekin's Avatar
I found some other website: http://www.pacificwrecks.com/airfields/kiribati/tarawa/
There is note about 204, 281 Kokutai, both had Zero´s and 755 Kokutai, which had G3M Nell.
In attached pictures are definitely wrecks of Zero´s.
I think that Gilbert islands fight was too soon for Ki-84.
ID:	1988717   Click image for larger version
Old 04-22-2014, 11:27 AM
  #196
Prekin
My Feedback: (19)
Prekin's Avatar
Here is some other Zero on Tarawa airfield. It looks like a A6M3 model 32 with clipped wings and cross in markings.
Old 04-22-2014, 10:57 PM
  #197
vasek
vasek's Avatar
Jirko, I see you're going all out on this project. NICE!
Hope to see this one in person. Cheers,V.
Old 04-24-2014, 07:31 AM
  #198
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you Vasek. One day I would like to see my Dauntless next to your Zero.
Old 04-25-2014, 10:51 PM
  #199
Prekin
My Feedback: (19)
Prekin's Avatar
This warbird has very short nose, because in the real it has radial engine. This is the reason why it needs some weight in the nose. RX and ignition batteries will be above the engine on the red mounting and electronic ignition will be on the right side of engine opposite the silencer.
ID:	1990011   Click image for larger version
Old 04-30-2014, 10:38 PM
  #200
Prekin
My Feedback: (19)
Prekin's Avatar
I found out, that I have to repair the silencer. After welding I sanded some material around the conection I sanded it too much. Now I have some holes and some cracks on the silencer. Yesterday I did a defectoscopic test. Here are two pictures.
ID:	1991504   Click image for larger version
