Reload this Page >
P-38 Lightning Brotherhood
Old 05-12-2015, 12:02 PM
  #1051
pilotbum
pilotbum's Avatar
Didn't know The Dirty Dog shipped...
Old 05-13-2015, 07:48 AM
  #1052
Chris Nicastro
Chris Nicastro's Avatar
This all of the nomenclature typically found on a P-38. You can print this off your computer on decal sheets.
NO STEP NO STEP NO STEP NO STEP NO STEP NO STEP NO STEP NO STEP NO STEP NO STEP
NO PUSH NO PUSH NO PUSH NO PUSH NO PUSH NO PUSH NO PUSH NO PUSH NO PUSH NO PUSH
CONTROL ACCESS CONTROL ACCESS CAUTION: REPLACE COVER CAUTION: REPLACE COVER
AILERON SERVO ACCESS AILERON SERVO ACCESS AILERON SERVO ACCESS AILERON SERVO ACCESS
AMO CAN ACCESS AMO CAN ACCESS AMO CAN ACCESS AMO CAN ACCESS AMO CAN ACCESS
GUN ACCESS GUN ACCESS GUN ACCESS GUN ACCESS GUN ACCESS GUN ACCESS GUN ACCESS
TIE DOWN TIE DOWN TIE DOWN TIE DOWN TIE DOWN TIE DOWN TIE DOWN TIE DOWN TIE DOWN
LOCKOUT VALVE LOCKOUT VALVE AUX. EQUIP. ACCESS AUX. EQUIP. ACCESS
JACK HERE JACK HERE JACK HERE JACK HERE CAMERA GUN SIGHT CAMERA GUN SIGHT
LOCKED LOCKED LOCKED LOCKED UNLOCKED UNLOCKED UNLOCKED UNLOCKED UNLOCKED
LIFT HERE LIFT HERE LIFT HERE LIFT HERE LIFT HERE LIFT HERE LIFT HERE LIFT HERE LIFT HERE
CANOPY RELEASE CANOPY RELEASE CANOPY RELEASE OXYGEN FILLER OXYGEN FILLER
INSPECTION INSPECTION INSPECTION INSPECTION INSPECTION INSPECTION INSPECTION INSPECTION
OIL DRAIN OIL DRAIN OIL DRAIN GROUND HERE GROUND HERE GROUND HERE GROUND HERE
SERVICE HERE SERVICE HERE SERVICE HERE SERVICE HERE SERVICE HERE SERVICE HERE
STARTER EXTENSION HEATER DUCT HEATER DUCT HEATER DUCT HEATER DUCT GLYCOL GLYCOL
REMOVE FOR U.S.ARMY P-38G-15-LO ENGINE OIL ENGINE OIL FLAP POP-UP TAB
GROUND HEATER AIR FORCES SER. 43-2212 13 U.S.GAL 13 U.S.GAL FLAP POP-UP TAB
DUCT CREW WEIGHT 200 LBS
OIL COOLER OIL COOLER INTER COOLER INTER COOLER
FUEL TANK FUEL TANK FUEL TANK FUEL TANK EMERGENCY EMERGENCY
90 U.S.GAL 90 U.S.GAL 60 U.S.GAL 60 U.S.GAL CANOPY RELEASE CANOPY RELEASE
COOLENT FLAP COOLENT FLAP GUN CAMERA HOUSING GUN CAMERA HOUSING
OIL COOLER FLAP OIL COOLER FLAP INTERCOOLER FLAP INTERCOOLER FLAP
SUPERCHARGER AIR INTAKE SUPERCHARGER AIR INTAKE
OXYGEN TANK ACCESS OXYGEN TANK ACCESS BATTERY COMPARTMENT
BATTERY COMPARTMENT LUGGAGE COMPARTMENT LUGGAGE COMPARTMENT
REMOTE COMPASS RUDDER RUDDER RUDDER HYD. LINES & HYD. LINES & PLUMBING &
INDICATOR PANEL ACCESS ACCESS ACCESS CONTROL CABLES CONTROL CABLES ELECTRICAL
PLUMBING & ENGINE CONTROL CABLES ENGINE CONTROL CABLES RADIATOR FLAP RADIATOR FLAP
ELECTRICAL ELECTRICAL ELECTRICAL CYLINDER CYLINDER
ENGINE MOUNT ENGINE MOUNT REMOVE FOR ELEV. ELEV. ELEV. ELEV.
FITTING FITTING GROUND HEATER PULLEYS PULLEYS PULLEYS PULLEYS
& PLUMBING & PLUMBING DUCT L.G. PIN L.G. PIN L.G. PIN
STARTER EXTENSION STARTER EXTENSION FLAP MOTOR FLAP MOTOR FLAP ACCESS FLAP ACCESS
FUEL TANK FUEL TANK FUEL TANK ATTACH LIFT LUG HERE ATTACH LIFT LUG HERE
INSPECTION INSPECTION INSPECTION USE AN3-5A BOLTS USE AN3-5A BOLTS
DON''T CAP DON''T CAP TAB ACT TAB ACT AILERON CABLE AILERON CABLE DIVE FLAP DIVE FLAP
RADIO COMPARTMENT AND SHELL EJECTION SHELL EJECTION SHELL EJECTION SHELL EJECTION
MAGNETIC COMPASS TRANSMITTER MAGNETIC COMPASS TRANSMITTER FLAP FLAP
KEEP ALL IRON AND STEEL AWAY KEEP ALL IRON AND STEEL AWAY CABLES CABLES
FROM THIS VICINITY FROM THIS VICINITY
KEEP ALL IRON AND STEEL AWAY KEEP ALL IRON AND STEEL AWAY CABLES CABLES.
FROM THIS VICINITY FROM THIS VICINITY AILERON BOOSTER
CAUTION CAUTION MECHANISM
DISCONNECT ELECTRICAL WIRING DISCONNECT ELECTRICAL WIRING AILERON BOOSTER
BEFORE REMOVING TAIL BEFORE REMOVING TAIL MECHANISM
CAUTION..DISCONNECT ELECTRICAL CAUTION..DISCONNECT ELECTRICAL
WIRING BEFORE REMOVING WING TIP WIRING BEFORE REMOVING WING TIP
AILERON AILERON AILERON AILERON AILERON AILERON AILERON
DEF. MECH DEF. MECH DEF. MECH DEF. MECH PUSH-PULL TUBE PUSH-PULL TUBE PUSH-PULL TUBE
Old 05-16-2015, 05:15 PM
  #1053
BigTeeEldorado
BigTeeEldorado's Avatar
Maiden flight 0-7 hundred tomorrow morning.
Old 05-17-2015, 03:49 AM
  #1054
70 ragtop
My Feedback: (24)
Good Luck!
Old 05-17-2015, 01:58 PM
  #1055
Chris Nicastro
ID:	2096596   Click image for larger version
Old 05-17-2015, 02:00 PM
  #1056
Chris Nicastro
This is a stencil guide for a plastic model kit I found online. I'll post more info on scale drawings.
Old 05-17-2015, 02:01 PM
  #1057
Chris Nicastro
ID:	2096598   Click image for larger version
Old 05-17-2015, 02:28 PM
  #1058
Chris Nicastro
Hey 70 Ragtop
By chance do you have any other nose art versions of your plane documented?
Im really liking the bare metal yellow nose and invasion stripes but I dont want to "copy" your plane. Mine is already in bare metal Im just down to final decisions on the scheme.
Also who did the stencils for you or was that you?
Old 05-17-2015, 03:32 PM
  #1059
Tony Gag Jr.
My Feedback: (124)
Tony Gag Jr.'s Avatar
Ragtop, what field do you fly at? Your 38 looks awesome!
Tony
Old 05-17-2015, 04:49 PM
  #1060
BigTeeEldorado
Went pretty good... http://youtu.be/eDpWCEC5ilw I might have overdone it with the trumpets thing!
Old 05-19-2015, 08:06 PM
  #1061
70 ragtop
My Feedback: (24)
Looks good Big Tee
That 2nd crash is the plane I just rebuilt!
Tony
I fly at Wiltonbury, how about you?
Chris
Placement sheet is perfect, except I can't read it. Do you have a larger version?? I looked on line, and didn't see anyone with that set in stock.
My plane is 20th FW 55FS. Believe the 77th and 79 all have yellow spinners and cowl fronts, but don't hold me to that. They were all based at Kings Cliff Northamptonshire England. The 55th had the triangle on the tail, the other two were a circle and a square. Lots of cool schemes Cali Cutie, Gentle Annie, Mamas Boy, Lucky Lady, Fast Jacks Go Bunny are some well know ones.
It was a toss up between Go Bunny, Lucky Lady, and Wrangler fpr me. I wanted to keep it simple and went with Wrangler.
Search the squadrons, and lots of stuff comes up, but unfortunately, a bunch is on flicker. I can't seem to figure out how to download pictures from flicker. Mine is ready to go except for prop change. It's sitting in the corner, waiting for blades
Here's a few that I have, good luck with your search
ID:	2097251   Click image for larger version
ID:	2097252   Click image for larger version
ID:	2097253   Click image for larger version
ID:	2097254   Click image for larger version
ID:	2097255   Click image for larger version
ID:	2097264   Click image for larger version
ID:	2097265   Click image for larger version
ID:	2097267   Click image for larger version
ID:	2097268   Click image for larger version
ID:	2097269   Click image for larger version
Name:	wrangler small.jpg
ID:	2097270   Click image for larger version
ID:	2097271   Click image for larger version
Old 05-19-2015, 09:03 PM
  #1062
pilotbum
pilotbum's Avatar
Originally Posted by 70 ragtop
Chris
Click on the pic once and it will open in the pop-up-ish window that isn't really readable. Then double click it again and it will open a larger version in a new tab. Then you can magnify it and it's readable. That's on a PC with Chrome...
Old 05-19-2015, 10:22 PM
  #1063
Chris Nicastro
70 ragtop
Thats the only version I have, maybe try what pilotbum suggested on Chrome or just on a PC with Windows 7. Did you try printing it because maybe its clear once printed.
Did you use Aeroloft for dry transfers?
I was looking at their site today and they have some good schemes for a large variety of planes. I would prefer water decals to dry transfers or better yet stencils I could use to airbrush with. Their rivets are nice too.
Nice Bug and Cat in your collection!!
Old 05-20-2015, 08:02 AM
  #1064
BigTeeEldorado
Looks good Big Tee
I've watched that video a couple times and when they carried the wreckage back to the trailer, spread it all out and talked about it, there was little chance it was going anywhere but to the landfill. Knowing that was the plane puts a more personal spin on the project and even more WOW in your rebuild. You absolutely turned the impossible into the possible.
https://youtu.be/nmHC2oyMxDI
Old 05-20-2015, 08:13 AM
  #1065
Tony Gag Jr.
My Feedback: (124)
Ragtop, I fly in Farmington but just joined Wintonbury as a backup and for the asphalt runway for small electrics.
Old 06-01-2015, 08:22 PM
  #1066
BigTeeEldorado
Getting the engines smoothed out and more comfortable with the flaps (reason for the long landing)
https://youtu.be/9ARz4GoxD4M
Old 06-02-2015, 02:13 PM
  #1067
samparfitt
My Feedback: (43)
Chris,
Thanks for the nomenclature.
Old 06-03-2015, 10:04 AM
  #1068
rusty55125
Making progress on my 1/4 scale P-38, maybe not a quickly as i would like but steady. I have make a new canopy mold and pulled some parts. I need to pull a actual canopy yet but getting there. The servos are all installed, as well as the initial engine engine installation. I removed the right hand motor off to test run, you can see the inline DA100 here
https://www.youtube.com/watch?v=zb6-jj0aW6A
Such a smooth running motor, typical DA!!
I still haven't ordered the parts for my gear, but hope to soon.
Scott
ID:	2100249   Click image for larger version
Old 06-03-2015, 12:20 PM
  #1069
Aros
I too am seeking a nomenclature cheat sheet. Like 70 ragtop said, what you posted Chris is perfect but too small to read. I wonder if there is a higher resolution file out there of that guide?
Here's my Legend Models P-38. Have a ways to go with the detail but it's starting to shape up.
ID:	2100263   Click image for larger version
ID:	2100264   Click image for larger version
Old 06-03-2015, 07:22 PM
  #1070
Chris Nicastro
Anybody try contacting them directly?
Old 06-04-2015, 07:35 PM
  #1071
70 ragtop
My Feedback: (24)
Chris
Found a new decal set, with placement sheets in France. As long as they actually show up, will scan and post when I get them. My plane is a combo of paint and transfers from Aeroloft. All I will say is they are half the cost of Promark, and you get what you pay for. Depends on what you plan to do I guess. A good looking plane to take to the field or events, no problem. Building with the intention of competing, I would go Promark. I think next time I am going to go with Callie masks, but still need those small transfers.
For prop decals, gear strut placards, ect you've got to check out Decal-it, REALLY nice and super cheap. I'll snap some pictures of some of his stuff and post. He also does custom decals and masks
http://www.decal-it.com/decal-it_2014_008.htm
Scott
That thing is huge! Looks great, going to sound pretty awesome with those two big twins sync'd up
Todd
Welcome to the "brotherhood"...lol. Not a lot of action here, hope that will change
ID:	2100483   Click image for larger version
ID:	2100484   Click image for larger version
Old 06-04-2015, 09:05 PM
  #1072
Chris Nicastro
A they say Buy nice or buy twice!
I hear you. I had the best results from laser cut masks and airbrushing them on. It's possible to cut 1/8 scale letters but its not easy. The P-38 would be slightly better. Not sure I can get this done soon enough. Im thinking Aeroloft for rivets and screws and basic nomenclature. We can find nose art later.
What do you think?
Decal it looks good too!
Old 06-05-2015, 05:45 AM
  #1073
70 ragtop
My Feedback: (24)
I used Chad Viech's rivets and showed a bunch of pictures in the RCG thread. Little bit of a learning curve, but I like them. I think they would be incredible on a painted plane once some age and weathering is added. Since ours are both bare metal finish, they are still pretty nice, just a little bit more of a learning curve.
I tried them over the paint, and under the paint on the wings. What I didn't like with them over the paint was you could see the side of the rivet in the sun. Once I weathered it, that edge darkened up, so it not noticeable, and actually looks pretty good. With them under the silver, I was unable to really work the paint to add "grain" and hand "buff" it to get that aluminum sheet look without damaging the rivets.
Now on the painted parts (black, white, olive drab) where the rivet was applied, then painted with no hand work required, they are awesome. Apply rivet, spray on color, and age/weather it. The rivet will bleed thru, easy to simulate dings and chips too, especially on the cowls .
For some reason, I have to resize pictures to post of RCU, but there is lots of pix posted on RCG http://www.rcgroups.com/forums/showt...274813&page=14
Old 06-06-2015, 05:49 PM
  #1074
Rvander
My Feedback: (81)
Well finally test flew my yellow aircraft p38. Awesome.. Dle35RA...flew like a baby!!!! Video here: https://www.youtube.com/watch?v=5U7_6sceXyc
Old 06-06-2015, 07:14 PM
  #1075
tuchadwick59
My Feedback: (31)
That is fantastic Rvander. Well done. I am putting up the P-38 that simply can't be built. Haha. Many of you know the story behind it. Turns out the guy who wanted to build it here in Tulsa has been diagnosed with some kidney issues and he couldn't out the time and effort into it.
So so it is for sale yet again. Perfectly new. Last year the cowlings, canopy, and wings were destroyed in an accident (Separate from the body) and we got all new replacements before Yellow quit selling them. Body of the plane has been perfect as it was not a part of the accident. This needs a good home to ascent builder. The covering has been started and it is pretty sharp.
http://www.rcuniverse.com/market/ite...itemId=1032125
