Reload this Page >
Topflite Giant P-47 Club
Old 03-02-2015, 07:40 AM
  #251
Lifer
Lifer's Avatar
I tried the 20x10x4 prop last year on a DLE 55 powered Tarheel Hal. As I said in a previous post, it turned 5500 on the ground and never unloaded in the air. It looked like it was flying at half-power all the time. The normal prop for the 55 is a Xoar 22x10x2 and it hits over 7000 on the ground and unloads pretty good in the air. I estimate its' speed at between 80 to 90 mph.
The next attempt will be with the bashed P-47 that I posted some pictures of Saturday. The G-62 tached 6000 on the ground and I know from experience with that engine that it will really unload once in the air. If it unloads about 1500 rpm, I reasonably expect to see 70 to 80 mph. It won't be the fastest of the 2, but will have a nice look.
I like the fishscale idea, but haven't tried one yet.
Old 03-02-2015, 11:04 AM
  #252
haefeli
haefeli's Avatar
I am wondering what the 19 x8 4 blade will turn on my dle55 ra engine that I bumped the compression on and did a little exhaust work on. At almost 130 delivered it becomes a huge mistake to be wrong on choice. I'm like the rest of you that a 2 blade doesn't look good on a warbird. On these planes scale is about 30 inch diameter 4 blade. The other day I had an idea about belt driven gear drive. Almost all the parts I need can be had dirt cheap from an industrial supply company called Misumi. The catalog I have at work is over 3000 pages and each page has 1000 possible make items. Real rpm of 2800 with even 26 inch 4 blade with 14 pitch should haul the mail. I need to do some math and sketch some drawings. I see things online but the money is unreal.
Old 03-04-2015, 07:39 PM
  #253
BobH
The only reason 4 bladed props were used in the full scale planes was to harness the power of the big engines on them.
Most early planes had 2 bladed props... even the early spits.
Old 03-05-2015, 06:32 AM
  #254
haefeli
haefeli's Avatar
true, but they spin slowly. less apt to cavitate and had huge paddles and big time pitch. I worked for years with an old man who graduated from a technical school in the 1930's in Detroit that he had airplane mechanic degree. he went on to invent deicing mechanism's for props and also the supersonic boomerang shaped prop blades. he once explaned to me that 2 blades less apt to cavitate and 4 blade more efficient at big mph.
Old 03-05-2015, 10:29 AM
  #255
radfordc
My Feedback: (14)
radfordc's Avatar
I finished covering the fuselage this morning. I really like the aluminum film from Hobby King that I used. It has a "grain" to it just like real milled aluminum sheet. The film sticks really well and shrinks up nicely to cover compound curves. And of course a pilot is needed to fly this thing.
ID:	2079034   Click image for larger version
ID:	2079035   Click image for larger version
Old 03-05-2015, 10:55 AM
  #256
Lifer
Lifer's Avatar
It really does look like aluminum. Can you buff it with steel wool?
Old 03-05-2015, 11:07 AM
  #257
TonyBuilder
TonyBuilder's Avatar
Is that like iron on plastic covering?
TB
Old 03-05-2015, 12:42 PM
  #258
haefeli
haefeli's Avatar
looks very nice, have you used this before? the Chinese coverings I have experienced have the habit of having the color separate from the film and then it is a problem to replace. the color stays stuck to the wood. it looks real though. maybe some 4 ought steel wool to remove the sheen.
Old 03-05-2015, 01:38 PM
  #259
radfordc
My Feedback: (14)
radfordc's Avatar
Well, It is "Chinakote" but it works well. This is the first time I've used the aluminum....I've used other colors and have also been satisfied. The film lifts off wood fairly well, but does sometimes leave the color adhesive behind. A little acetone takes it off. I haven't tried buffing it with steel wool. This is the one I'm using: http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old 03-05-2015, 03:16 PM
  #260
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Progress on my 47. Got the Elevator bottom skins on..will finish the H-stab skins next
Old 03-05-2015, 04:13 PM
  #261
TonyBuilder
Cool, always love to see a new TFGS P-47 being born. I'm curios to how many are around these days?
TB
Old 03-06-2015, 06:27 AM
  #262
haefeli
haefeli's Avatar
I get pissed to see guys having fun, I miss stickin sticks together so much when I am at my point of build. if I were retired I'd have 2 projects going. beautiful glue joints.
Old 03-06-2015, 09:59 AM
  #263
radfordc
My Feedback: (14)
radfordc's Avatar
Yeah, the first 90% of building a plane takes 10% of the time and the last 10% of building takes 90% of the time!
Old 03-06-2015, 01:04 PM
  #264
Chad Veich
My Feedback: (60)
Yup, that's where the saying "90% completed with 90% left to go" comes from!
Old 03-06-2015, 04:30 PM
  #265
TonyBuilder
Seams I'm always at 90% left to go
TB
Old 03-07-2015, 08:50 AM
  #266
radfordc
My Feedback: (14)
radfordc's Avatar
Just about finished. Every thing covered and all equipment installed and working. Only thing left to do is paint the cowl and put on the markings. The plane weighs 19 lbs as she sits now.
Old 03-07-2015, 10:45 AM
  #267
TonyBuilder
Looking good, man that's light! My last one was 37lb wet.
TB
Old 03-07-2015, 12:57 PM
  #268
radfordc
My Feedback: (14)
radfordc's Avatar
I was surprised at the weight, too. Especially, with the on board electric start. I guess it's possible my scales are a little off?
Old 03-07-2015, 01:01 PM
  #269
TonyBuilder
Most light kits build in the 25-30 range glassed, ARF are in the 25+- range, more scale detailed kits are 30+
I cant see this kit being less then 23+- unless you have fixed gear, and no thrills.
TB
Old 03-07-2015, 03:40 PM
  #270
radfordc
My Feedback: (14)
radfordc's Avatar
I reweighed it with a digital scale and it weighs 21 pounds.
Old 03-08-2015, 04:42 PM
  #271
haefeli
haefeli's Avatar
got some work done. Alum. Is finished. Finished my exhaust plates. I need some .010" alum. To make my vent shrouds. I have extra clearance around exhaust pipes. Not real scale but I need to bleed heat from all over. Still looks pretty nice I guess. I'll work on opening up spokes on my rims and soldering in some nav. lights . I have so little time and I hate to quit working on Sundays.
ID:	2079891   Click image for larger version
ID:	2079892   Click image for larger version
ID:	2079893   Click image for larger version
ID:	2079894   Click image for larger version
Old 03-09-2015, 01:40 PM
  #272
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Exhaust looks awesome!
Old 03-09-2015, 01:45 PM
  #273
haefeli
haefeli's Avatar
Thanks. Just a copy from the "Zombie" plane at top gun a while back. This is what this will be. I had it going long before we all saw it in MAN magazine. I wasn't going to change my dream after someone best me to the punch with an awesome Miester Scale set up. I'm happy.
Old 03-09-2015, 02:09 PM
  #274
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
What size engine?
Old 03-09-2015, 04:26 PM
  #275
haefeli
haefeli's Avatar
DLE55RA the has a thinner base gasket and I widened the exhaust port and raised it .025 inch which equates to .010" after thinning up the base gasket.
