Reload this Page >
Topflite Giant P-47 Club
Old 03-31-2015, 08:45 AM
  #426
haefeli
haefeli's Avatar
Http://wikidot.com/p-72
The big brother
Old 03-31-2015, 02:08 PM
  #427
HoundDog
My Feedback: (49)
HoundDog's Avatar
The big brother
What? don't understand PLZ.explain
Old 03-31-2015, 02:20 PM
  #428
haefeli
haefeli's Avatar
It was supposed to be a link to this airplane that had a much bigger radial and came from same factory on long island the p47 came from. The computer at work didn't copy over entire link. Google this plane and I'm sure you'll see the wikidot site near the top. Lots of info and might make a cool project.
Old 03-31-2015, 02:21 PM
  #429
haefeli
haefeli's Avatar
If I remember it was supposed to be tbo. After the http:/
Old 04-01-2015, 02:42 AM
  #430
TonyBuilder
TonyBuilder's Avatar
[attach=config]2085588[/attach] [attach=config]2085589[/attach]
tb
ID:	2085588   Click image for larger version
Old 04-01-2015, 06:19 AM
  #431
haefeli
haefeli's Avatar
My work computer has so may filters on the system it wouldn't let me load the write up on this plane. Bigger engine. Almost 4000 horse power on tap. I think it said 100 were made.
Old 04-01-2015, 02:40 PM
  #432
haefeli
haefeli's Avatar
Somehow I integrated a RXCL optical kill switch into the main shut off harness. Man I am lousy at electronics.
Old 04-06-2015, 11:39 AM
  #433
haefeli
haefeli's Avatar
slowly coming around, didn't get to spend as much time as I wanted over the holiday but the radio installation is going good. it will use 9 channels in all.
ID:	2086840   Click image for larger version
Old 04-06-2015, 01:07 PM
  #434
Lifer
Lifer's Avatar
Very nice!
Old 04-06-2015, 03:44 PM
  #435
captainron
captainron's Avatar
Looks Awesome.......haefeli
Are you going to burnish down so not so shiny......like mine...........or leave it shiny and pretty...?
Name:	2002-01-01 00.00.00-1.jpg
ID:	2086894   Click image for larger version
Old 04-06-2015, 03:50 PM
  #436
captainron
captainron's Avatar
oops....didn't mean to get the little Hanger 9 jug in there......just the Top Flite on top....
Old 04-06-2015, 03:58 PM
  #437
captainron
captainron's Avatar
Here's a better pic of her
Old 04-06-2015, 06:29 PM
  #438
TonyBuilder
What? Shinny is not good
TB
Old 04-07-2015, 04:00 AM
  #439
captainron
captainron's Avatar
Dang.............she sure is PURRRRRDY...
Old 04-07-2015, 05:30 AM
  #440
haefeli
haefeli's Avatar
these planes are beautiful. first I need to get basic assembly then lay my tape lines and prep the surface for invasion stripes. then I will take and see what different finishes look like on scrap test pieces.
Old 04-12-2015, 04:32 PM
  #441
haefeli
haefeli's Avatar
finally finished the tail area. Everything is located under the hatch for radio and air. Where is the scale fuel door located. Is it forward of canopy starboard side at 2 o'clock position.
ID:	2088453   Click image for larger version
Old 04-13-2015, 09:39 AM
  #442
TonyBuilder
I got my artwork done on my jug, for those that want real art airbrushed Amy is charging $100-$150 depending on the scale and scope, mine was $100
TB
Old 04-13-2015, 12:18 PM
  #443
haefeli
haefeli's Avatar
Pretty racey stuff Tony. Hey where is the fuel fill location.
Old 04-13-2015, 12:35 PM
  #444
TonyBuilder
Right side hatch
TB
ID:	2088744   Click image for larger version
Old 04-22-2015, 11:40 AM
  #445
haefeli
haefeli's Avatar
Tony it looks pretty cool, I see whee you built in the access door. looks nice. I put all my stuff in a removeable hatch behind the tail wheel. it never dawned on me to do what you did but its only my 3rd build since I was 12 or 13. do you know where the full scale fuel fill location is? I have a 30mm dia. fuel filler from hobby king that looks good and I thought I would use it. being round causes some issues as I will have to modify to fit onto a curved surface.
Old 04-22-2015, 01:31 PM
  #446
TonyBuilder
Wings I would think!
TB
Old 04-23-2015, 11:38 AM
  #447
haefeli
haefeli's Avatar
I thought it was a door on rh side of fuse forward of the cock pit. I cant get into this forum from my cell phone anymore. I pick on forums and it goes straight to the rules section. not much fun when I cant get into the site from home.
Old 04-23-2015, 12:30 PM
  #448
teamscalepilot
Here my finished ARC. DA-50, Robart Electric gear, Futaba gear, .6 oz glassed with ZAP Zpoxy finished with Flite Metal. 26.5 lbs got 3 flites on it, flies like a big trainer. takeoffs and landing are easy withe the wide gear. the huge wing just nibbles at the stall with no wing falling off to a spin. a lot easer to fly than the TF P-51. The Flite Metal shines nice in the sun.
Old 04-23-2015, 12:55 PM
  #449
TonyBuilder
Looks greats, mine should be done next month. I'm hoping for 30lb
TB
Old 04-23-2015, 05:20 PM
  #450
haefeli
haefeli's Avatar
Its nice to see a nice plane sitting in nice green grass. Mine turned white yesterday. Can't believe it. How fast do you think it flies. Tony your plane is looking sharp too. I am busy sequencing the jomar unit and do final fitting install for my air lines. From the receiver I have the sequencer that will first open inner doors then it will cycle the servo to actuate air valve for retracts. I have it set to operate the doors in a 2 second cycle, then 2 seconds later move servo for air valve. I want the safety factor so I don't blow open inner doors with my struts.
