Meister Scale Zero- How accurate is it?
My Feedback: (7)
How accurate in outline is the Meister Scale Zero? Is it like some of the other Meister kits in that it has a flat bottom airfoil and is more standoff scale?
The closest arf i've seen out of the box that correctly copies the profile would be in my opinion the top-flight zero arf. That's the only thing I've seen out of the box that is close
The tip airfoil was 9%. This could easily be verified by Dino if you shoot him an email. If it is that important to have scale airfoils, It would be easy to make replacement ribs to match. Of course if going to an airfoil that may possibly be less stable, verifying good washout would be in order. Keeping the weight down is always a good idea as well.
My Feedback: (7)
Thanks guys. Chad, how it compares with the older flat-bottom Meister designs was basically what I was getting at. I don't need a totally scale airfoil, but I don't want the awful looking flat bottom of the older Meister Fw-190. I wish someone like Jerry Bates (or Chad Veich) would draw up a big Zero plan.
My Feedback: (60)
I appreciate the confidence Jack and the Zero is pretty high on the list of aircraft I would like to model. Indeed I started down the path of drawing one some years back but did not get too far before it got stuck on the back burner. It was a smuch smaller model however. I'm not sure I could do any better than the Meister anyway. If you look at Ken Safer's model seen below it looks pretty darn good to me. Not sure what, if any, changes he made but obviously the Meister airplane has potential. And having seen Ken's bird fly on several occassions I can offer that it appears to be VERY well behaved. As are most Zero models I think. I believe Bates is working on a Ki-43 Oscar if that might be of any interest.
I'll put it to you this way... A Meister Zero just came in second place at top gun in Pro Am class. A Meister Jug just won it. I just bought my second Meister Zero this weekend... You wont find a better FLYING warbird...You can make it as scale as you want.
Thanx
Rebel
Thanx
Rebel
AB, CANADA
Here's my Meister, I don't think that the flat bottom airfoil detracts from it at all. There is a lot of other scale detail that if done poorly will draw your eye in rather than your eye being drawn to the airfoil.
