Top RC Zero from Gator R/C
#426
#427
#428
jim
#429
fg84 baffled
Hi
My fg 84 with annulair exhausst is also baffled.
I have used the original mounting stands and moved forward the cowl + modification of the position of the false exhausst : it is no scale but i get more air out back of cowl.
Without this modification my motor was very hot.Now after flight i can put my fing on cylinders without burn me.
Other advantage : less weight add
Had another dead stick today with the Saito fg84/Keleo combo. The engine is baffled. Not sure if I'm getting enough air out the back of cowl. The Keleo does tend to block flow. Might be over-heating. Still trying to figure out. I believe the prop is a biela 3-bladed 22x10. Performance is fine...very scale like. Deadsticks are troubling.
jim
jim
#432
#435
It's not easy to remove the stock graphics. If you look back, you'll see that I did. For some reason I didn't post the procedure. First it is best to get some of the clear coat off. I used a fine sandpaper sponge to do that. Than I used some acetone to get the graphic off. I don't think it's possible to get the numbers off without some of the green coming off with it. I matched up some green using Testor's paint and made it look good.
#439
Help mounting fg84r3 w/keleo ring
I see where some are mounting the fg84r3 with keleo ring and using stock standoffs. I am using what I think are the stock standoffs (aprox 3/8" thick). My problem is the exhaust dump spout is hitting the fake air scoop on the bottom of the fuse. Has anyone had this problem and how did you fix it?
Thanks in advance
Gary
Thanks in advance
Gary
#440
Thanks in advance
Gary
Thanks in advance
Gary
#446
Did you eliminate the mounting ring completely and just leave the mounting blocks?
Did you have to extend the blocks for attaching the cowl? Looks like your cowl mounting screws are sitting next to the cowl flaps.
jim
#449
