glow to gas
MD
glow to gas
hey fellas....i just wanted to ask this question. I have the Topflight .60 size P-51 Mustang and I would like to put the Saito 14cc gas motor on it....is this motor enough or to little?
MD
Thanks Gizmo....the 20 sounds great and the speed is not an issue since I have a couple that do over 100. So I think I'll do the Saito 21cc gas to get that 4 stroke sound. Will definitely post a vid so youc can see how it turned out. Thanks for your help
MD
ok guys the debates continues....now I have have noticed in the provided specs for 4 stroke engines and gas engines that they are basically the same as far as CC output....does anyone have any first hand experience with this
MD
I'm sorry Bob....I should have been more clear. The comparison is between 4 stroke gas and 2 stroke gas....in particular the Saito 21cc 4 stroke gas vs the DLE 20cc
MD
Well the specs and prop size are almost identical. Now the gas issue isn't the same with one engine requiring 20-1 while the other is 30-1. Again not that big of a deal. Which leaves sound and price....it is a scale war bird. And that 4 stroke would sound great on her. Thanks for your input. I'll fill you in on my choice. Blue skies to you.
