Reload this Page >
NEW Legend Models 79.5" F8F Bearcat!
Old 08-30-2016, 07:20 AM
  #101
JohnVH
My Feedback: (38)
JohnVH's Avatar
Thanks! I think so too!
Old 08-30-2016, 11:36 AM
  #102
baronbrian
My Feedback: (13)
baronbrian's Avatar
Looks amazing! how much ballast did you end up needing?
Old 08-30-2016, 01:08 PM
  #103
JohnVH
My Feedback: (38)
JohnVH's Avatar
about 3.5lbs
Old 08-30-2016, 03:59 PM
  #104
ltc
Originally Posted by JohnVH
about 3.5lbs
i think that pretty much makes an electric power build impractical
Old 08-30-2016, 04:22 PM
  #105
ccostant
My Feedback: (38)
ccostant's Avatar
On radial engine warbirds I always think Zenoah first. Typical you need the weight up front anyway and Zenoahs are pretty much bullet proof plus they dissipate heat much better than the lighter engines. For inline engine warbirds then I think DA, DLE, RCGF, ..etc.
A G38 is almost 1.75 lbs heavier than the DLE35. if you really want it to haul then a G45 is 2.2 lbs heavier than the DLE35. Even at that you still need lead in the nose to balance but at least it's a lot less.
The Bearcat looks great. I'm definitely considering one for my Zenoah G38. Waiting to see how your maiden flight goes. Good luck,
Old 08-30-2016, 09:39 PM
  #106
JohnVH
My Feedback: (38)
JohnVH's Avatar
Guys, she flew!!!!!! Typical warbird, needs nose weight. Don't sweat that.
Flew light, the landing was sooooooo great!!!! A 55 would be great too, but not needed. It was not lacking on power at all. Flew around at half throttle.
It jumped off the ground, 3 clicks of aileron and it tracked like a pattern ship.
I'm so happy. Pics and video coming. This is a winner! Everyone at the field was impressed! Weight is not an issue, with full flaps it almost hovers it flies so slow.
Old 08-31-2016, 07:21 AM
  #107
JohnVH
My Feedback: (38)
JohnVH's Avatar
why?
Old 08-31-2016, 07:59 AM
  #108
JohnVH
My Feedback: (38)
JohnVH's Avatar
She flew! And she flew GREAT!!!
ID:	2179077   Click image for larger version
ID:	2179078   Click image for larger version
Old 08-31-2016, 08:29 AM
  #109
ltc
why?
If a gas engine install requires 3.5lbs of ballast, an electric install will likely require even more.
I once did an electric build of a 50cc plane (used a Hacker Q80-7m) and I not only had to place the batteries up in the cowl under the motor, I had to use 8000maH packs just to get the CG close.
I'm just not sure it's practical in this plane. I may be wrong, who knows.
Old 08-31-2016, 08:47 AM
  #110
JohnVH
My Feedback: (38)
JohnVH's Avatar
The batteries can be slid all the way to the back of the firewall. Even if you have to add weight, I dont see a problem. I had a 82" T-6 I converted to electric, with the battery on the firewall it still need a couple pounds of lead. Shouldnt be an issue.
Old 08-31-2016, 09:34 AM
  #111
JohnVH
My Feedback: (38)
JohnVH's Avatar
TEASER!
Debrief, on the high speed taxi run I could tell with just half throttle it was light on its feet, with full takeoff power it took off very predictable, nice climb out with only 3 clicks of aileron trim needed.
Cleaned up it cruised around great at half throttle! Full throttle climb out was great, a 35 is enough power, a 50 would be even better with a big scale 4 blade on it! But I have zero complaints.
Flaps are very effective, I didn't see one bad habit at all, with full flap slow flight it would keep going straight. I landed in light winds with half flaps and it slowed down for a nice 3 pointer.
Cant wait to fly it again.
https://www.youtube.com/watch?v=V-PdN7p6DVs&feature=youtu.be
Old 08-31-2016, 09:41 AM
  #112
Lifer
Lifer's Avatar
I told you it would be alright!
Old 08-31-2016, 09:42 AM
  #113
JohnVH
My Feedback: (38)
JohnVH's Avatar
The internet made me nervous, haha, you were, and it was awesome!
Old 08-31-2016, 09:44 AM
  #114
Lifer
Lifer's Avatar
These threads are FULL of armchair experts.
Old 08-31-2016, 10:24 AM
  #115
Denfly31
Denfly31's Avatar
Awesome! I think I'm going to stick with the 40 twin. I have a DLE 55ra I was considering for the noise weigh. Guess I have to find some lead though. Will be taking off work tomorrow to get a full day of work in.
Old 08-31-2016, 10:55 AM
  #116
Gmann6843
TEASER!
Nice Maiden flight!!!!!!!!!!!! A few more fights and you might be able to transfer some weight and lose some of that 3.5lbs. When you think about it losing that 3.5 pounds will put you close to the specs of the plane.
Old 08-31-2016, 10:57 AM
  #117
ltc
You're probably right.
Just have an aversion to adding dead weight to an airplane, especially a wooden airframe on a grass field
I'll wait and see how someone else does with an electric build...
Old 08-31-2016, 11:00 AM
  #118
JohnVH
My Feedback: (38)
JohnVH's Avatar
Most rc warbirds need weight, nothing you can do about that. Just how it is with short nosed radial warbirds. You cant tell in flight that it has it.
Old 08-31-2016, 11:01 AM
  #119
JohnVH
My Feedback: (38)
JohnVH's Avatar
Thanks! Maybe, as light as it feels on the sticks, I have no need to change a thing, its perfect!
Old 08-31-2016, 11:52 AM
  #120
Gmann6843
JohnVH....I just happened to be on the VQ models web site.I was trying to find out information on what type of covering their using. I ended up sending a email, so we will see just how good and quick their customer service department handles my request. I did notice that the F8F Bearcat in one of the pic's had the ignition module aft of the fuel tank.I will attach the pic seems the tank could be slided back closer to CG as well.just brainstorming getting ready to pull the trigger as soon as I find out what covering works with this aircraft because I plan to use a retractable tail wheel. If I don't find out the color I will think of a contrasting color in it's stead............................................. .................................................. .................................................. .................................
Old 08-31-2016, 12:17 PM
  #121
JohnVH
My Feedback: (38)
JohnVH's Avatar
With the need for nose weight, sliding things closer back to cg is not what you want to do. Id be curious to see how others come out, maybe I got a heavy one.
My cg was right around the 6" mark IIRC
Maybe you can get them to send you an extra sheet of the covering, its sticky back, like a sticker. It comes with a full page of it.
Old 08-31-2016, 01:58 PM
  #122
baronbrian
My Feedback: (13)
baronbrian's Avatar
Well done! Very nice landing as expected! They are going to sell a lot of these.
Old 09-01-2016, 09:57 AM
  #123
JohnVH
My Feedback: (38)
JohnVH's Avatar
Full length video
https://www.youtube.com/watch?v=HHCFkYmPNnE&feature=youtu.be
Old 09-01-2016, 12:09 PM
  #124
Lifer
Lifer's Avatar
Good job!!!!!!
Old 09-01-2016, 12:33 PM
  #125
JohnVH
My Feedback: (38)
JohnVH's Avatar
Good job!!!!!!
Thanks! It was tracking like a pattern plane, I was very happy.
