Reload this Page >
Black Horse P-47 Thunderbolt 60cc?
Old 03-17-2022, 06:53 AM
  #201
Prekin
My Feedback: (19)
Prekin's Avatar
Originally Posted by alsummer
Is this plane fully sheeted without lightning holes?
I'm not sure, I didn't remove covering. If there are some lightning holes, I guess that they are only on the bottom side of wings.
Old 03-17-2022, 07:20 AM
  #202
Txmustangflyer
From pocs on fb of one..also turtle deck behind cockpit, but none in high "stress" areas.
Old 03-17-2022, 09:57 PM
  #203
RoysterDW
RoysterDW's Avatar
Question
Originally Posted by Prekin
Here are some shots of the BH 60cc P-47. Two pieces wings are great for warbird of this size. As usually there are some blemishes such as paint scheme or flap angle indicator on flaps. But the weathering on self adhesive covering is nice. I was suprised, that she is not covered by oracover or solarfilm but by some self adhesive coat. I am going to replace the cockpit and some other parts such as dummy radial engine and wing pylons.
Where did you get your pilot from?
Old 03-17-2022, 10:01 PM
  #204
Prekin
My Feedback: (19)
Prekin's Avatar
That is only bust I got from ebay years ago.
RoysterDW (03-17-2022)
Old 03-17-2022, 10:46 PM
  #205
RoysterDW
RoysterDW's Avatar
Thumbs up
Ok. As much as I would like a WarbirdsPilot.com pilot, but at $152 AUS I'm thinking about just leaving the BlackHorse one in and maybe touch him up a bit.
Old 03-17-2022, 10:52 PM
  #206
Prekin
My Feedback: (19)
Prekin's Avatar
I'm going to 3D print pilot for my P-47. Purchased some files on ebay. Last year I print him for my P-51.
Old 03-17-2022, 10:54 PM
  #207
RoysterDW
RoysterDW's Avatar
Question
Wont that be heavy?
Old 03-17-2022, 11:14 PM
  #208
Prekin
My Feedback: (19)
Prekin's Avatar
I would like to finish mixture quadrant later today. Side panels are painted and now I must to finish some detailing.
ID:	2271584   Click image for larger version
ID:	2271585   Click image for larger version
Old 03-17-2022, 11:22 PM
  #209
Prekin
My Feedback: (19)
Prekin's Avatar
Wont that be heavy?
No he, wont, why he should be heavy? The 1/7 scale pilot with trimmed legs was about 40g.
Old 03-18-2022, 09:04 AM
  #210
Prekin
My Feedback: (19)
Prekin's Avatar
The side panels are not done yet, but I did some progress. I spent some time with new design of the throttle lever. The new one is more detailed and also designed for gyroscopic gunsight.
ID:	2271587   Click image for larger version
ID:	2271588   Click image for larger version
ID:	2271589   Click image for larger version
ID:	2271590   Click image for larger version
Old 03-22-2022, 08:02 AM
  #211
Prekin
My Feedback: (19)
Prekin's Avatar
All of the gauges are under glass now. Finally I can add the missing placards and switches.
Old 03-23-2022, 10:06 AM
  #212
Prekin
My Feedback: (19)
Prekin's Avatar
Dry assebled cockpit. Side panels are not finished yet.
ID:	2271606   Click image for larger version
ID:	2271607   Click image for larger version
Old 03-24-2022, 10:02 AM
  #213
Prekin
My Feedback: (19)
Prekin's Avatar
Cockpit side panels are done. The oxygen tube I will add when I fit pilot into his office. Probably I will do also some postshading on the side panels.
ID:	2271612   Click image for larger version
ID:	2271613   Click image for larger version
ID:	2271614   Click image for larger version
RoysterDW (03-26-2022)
Old 03-26-2022, 02:11 AM
  #214
RoysterDW
RoysterDW's Avatar
Finally after almost a year waiting I got my P47!
looks like a few things have changed since it’s first release.
Old 03-26-2022, 02:15 AM
  #215
Txmustangflyer
I'll say!
Actual carbon fiber or just a look alike?
Old 03-26-2022, 02:34 AM
  #216
RoysterDW
RoysterDW's Avatar
Originally Posted by Txmustangflyer
I'll say!
Not sure. It’s sandwich of ply and a composite material of some kind. They have also sheeted the inside with some kind of covering.
the retract controller is labeled Phoenix which proves it’s from the same factory as Phoenix.
Old 03-26-2022, 03:15 AM
  #217
Prekin
My Feedback: (19)
Prekin's Avatar
It looks they use carbon-plywood sandwich on construction now, same as Phoenix models.
But I do not see any balsa sheeting on fuselage. So, P-47 for 3D flying?
Old 03-26-2022, 03:31 AM
  #218
Txmustangflyer
Its sheeted with something.
If its a compisite sandwich, then very strong. But, watch your rx antenna placement.
Old 03-26-2022, 03:41 AM
  #219
Prekin
My Feedback: (19)
Prekin's Avatar
I see only BH covering film.
Old 03-26-2022, 03:45 AM
  #220
Txmustangflyer
Too thick to not have some kind of sheeting ubder the iron on. Look at fuselage edges.
yes, theres lightening cutouts but ...looks real good, potentially a good structure. As long as glue joints are good, it should be strong.
What does the engine box look like?
Old 03-26-2022, 03:51 AM
  #221
Prekin
My Feedback: (19)
Prekin's Avatar
Dont forget, that BH use self adhesive covering.
Old 03-26-2022, 04:23 AM
  #222
Txmustangflyer
Even so, covering isn't that thick bud.
Old 03-26-2022, 04:28 AM
  #223
Prekin
My Feedback: (19)
Prekin's Avatar
We will see if Royster will share some more details with us.
Old 03-26-2022, 07:11 AM
  #224
Txmustangflyer
Look at circled spot, there seems to be some thuckness to the cf on top of the ply piece.
could just be the angle.
Old 03-26-2022, 09:27 AM
  #225
Prekin
My Feedback: (19)
Prekin's Avatar
From the picture I see on the plywood-CF sandwich.
But on the bottom among formers I see only covering.
