.40 size Yak 3. Designing and building
RE: .40 size Yak-3. Designing and building
ORIGINAL: mihaj
You are right about I-16. Sorry, but Pe-2 was designed by Petlyakov.
They are on my todo list as well.
Cheers
Cheers
#32
16. Cockpit sheeting installation.
We will cut out most of it at the canopy fitting and installation stage.
#36
ORIGINAL: Patrick Underwo
Hey, good for you. MORE RUSSKY SALMOLYETS!
(That's "Russian Airplanes" for you capitalist types)
Patrick
Patrick
That would be BOLSHE RUSSKIH SAMOLYETOV!
#45
27. Preparation for wing sheeting.
1/16 x 4 x 48 balsa sheet cut by half and glued together. Then cut diagonally as shown on the picture.
#46
28. We are using our favorite sheeting technique.
Applying thin layer of Elmer's white glue on sheeting and top of the ribs and let it dry for about 20 - 30 min.
#47
29. Using sealing iron on the maximum temperature iron down sheeting to adhere it to the wing structure.
Note: Wing is still pinned down to the building board to insure that it is straight and true.
