World Models ZERO GS - which muffler with a G45?
My Feedback: (41)
FL
If anyone is using a G45 with the WM Zero GS, will a J&A Pitt's muffler fit between the engine and firewall?
What muffler are you using with the G45?
Howard
Howard
Probably not. There's not much room behind the engine to clear the Pitts style without carving away a lot of the engine box.
I am using a G-38 with a rear mounted J'TEK muffler and I have to cut a chunk out of the box.
For a G-45 with a side mounted exhaust outlet, any of the "cannister" mufflers will work. Not the 3-D type of canister, I'm talking about the type that come with a lot of engines, black sheet metal with one or 2 outlet pipes. There's lots of roonm on the sides of the engine, but none at the back.
Maybe a J'TEK or Bennett muffler, as long as it only sits on the side of the engine, not the rear.
