B-36 Peacemaker
Old 05-04-2003 | 07:58 PM
Default B-36 Peacemaker
Does anyone know where I can find plans (of any scale) for a B-36 Peacemaker??? My Grandfather was ground crew for this massive plane and I would love to build it. In case you haven't seen one- it has Six pusher props and a jet pod on either wingtip (with two jets in each pod)[img]i/expressions/face-icon-small-shocked.gif[/img] . Thanks for your help fellas.
Old 05-10-2003 | 04:05 PM
My Feedback: (32)
not plans but usable 3-views that you can use to create plans
http://www.airwar.ru/other/draw/b36h.html
Old 05-12-2003 | 01:22 PM
thanks for the info- I'll check it out.
Old 05-12-2003 | 06:03 PM
Banned
I know of someone building an appx 32 ft long model of the B-36... (anyway, he needed a custom built 32 ft traier to haul the fuselage...)
Might be flying this year. If it is, it'll be at the Waco, TX Big-Bird Fly-in June 14. (if it isn't he should be hauling it there for display anyway...)
Old 05-16-2003 | 09:30 AM
I got a nice set of plans off of EBay... electric powered, managable size but still big...
They are out of Electric Flight International, plan #MW2786 designed by John Considine. Uses 6 speed 400s...
Hope this helps!
- John
Old 06-08-2003 | 07:28 PM
Steve V.'s Avatar
There were two B-36's at Bomber field this weekend. They flew well and fast. You might contact someone at Bomber field to get the pilot information. They had somewhere in the 6'-8' wingspan range.
http://bomberfield.sytes.net/
Steve V.
Old 06-11-2003 | 05:33 PM
I see in ebay's "new today" items plans for the B-36 peacemaker.(06-11-03) 115" wingspan. Item # 3134762860. They're claimed to be beautiful. I hope this helps.
Old 06-19-2003 | 06:20 PM
he hasn,t finished the big 36 yet but he should have it at bomber field in september for display he said robart wouldnt build his gear it was too complex so he,s building it himself i believe the size is actually 20 foot span he,s projecting 96-100 lb,s finished weight with six g-38,s on board
