TF GS P47 Build - yeah another bloody one!!
#5601
RE: TF GS P47 Build - yeah another bloody one!!
ORIGINAL: rt3232
Old Tom
Tryed to post last nite but sys would not let me and I don't have a clue as to why
About the chin piece coupla of ways both alot of work, I have done both on different birds. First if you have the ABS cowl that came with the kif with care you can cut out the lower part to fit acros and reshape with a little heat,and make the stand off's out of wood and glass it all together, next is to sculpet on out of blue foam add a layer of glass and Install, or with the foam part sand and fill till it is glassie smoth and use it as a mold ,from it you have to make a female mold and then make your part with casting risen and microbloons.
thre outher option is to try to contact aero-tec (Pete may have the e-mail or phone) they didi have a kit that was vary nice mabe a bit spendy but great quality of parts. have not seen there add in a long time and some rummers they were going out of bus.
Another option would be to PM G-Pete he may have a better plan or ideas
Hope this helps
Cheers Bob T
Old Tom
Hope this helps
Cheers Bob T
Thanks Bob.
I talked to the guy at Aerotech in the begining of January.He is trying to sell the business and said to keep checking the web sight. They will post the change of ownership when it happenes.
That was a great web site and lots of good stuff for scale builders.Good luck to him in his retirement.
Old Tom
#5602
ORIGINAL: Bob Parker
Hey Tom
Please build a Corsior, I never could get Eugine to build one. Your plane is coming along great.
Bob
Hey Tom
Bob
If I had a Corsair I wouldn't let you Fly it anyway cause you don't like the way they fly.He He He.Does that grin remind you of Your Buddy Bill?[:'(][:'(][:'(]
Old Tom
#5603
Good morning guys,i need to find out bthe correct colour that was used insde the wheel wells and tailwheel area??? Im sure someone knows this on this great subject.Just waiting for the weather now.
heres a pic of our two new winter projects. Both tf giant scale birds. regards ray
#5604
ORIGINAL: OZYRAY
I put down 2 coats of silver then smeared on the Zinc Chromate with a brush. It gave it a nice chipped paint effect.
you can find my pictures. on Pg. 248.
You built 2 planes in 1 winter! I'm impressed.They look good to.
Old Tom
#5605
Thanks for your help.The p51 was built by my mate john jackson from Chester England.He has done a dam fine job!!! ray
#5606
There are many shades of zinc chromate. Some more yellow some greener. Tom is right on, put down a coat of silver then the zinc chromate. It gives it a realistic look.
#5607
I've been working on the Horton Servo Mounts.
It is taking longer than I tought it would,but it's looking good.[sm=thumbs_up.gif][sm=shades_smile.gif]
Flaps are dunn,Ailerons to go.
Old Tom
Old Tom
#5609
Banned
good work there Tom
RT how goes that bloody Cub?
I have done pretty much all the rivets on the starboard side of the fuz, fin and stab are next.
#5610
ORIGINAL: Peter_OZ
good work there Tom
good work there Tom
Old Tom
#5611
Banned
well it works well but needs to be sharpened now after about 2500 or so rivets. What method do you reccomend?
cheers
me
cheers
me
#5612
ORIGINAL: Peter_OZ
cheers
me
cheers
me
The tried and true method .Execto blade and drill press just like the original.
2500 Wow, what did I get myselfe into?
Old Tom
#5613
Pete
The Cub covering thing is done not as nice as I would like but it is just a cub, got the stripe down the sides and have started installing stuff still have to pick up some cub decals for some eye dressing , will most likly have it done and ready to balance this w/e
Sure glad there no rivets on the cub speaking of rivets are you seeing 3 at a time yet
We are having a heat wave to day it might get to 30 deg F the cold is finaly getting to me if it last another week I just may go in and hibernate[&o]
Bob T
Bob T
#5614
That looks really good Tom. It takes a little bit but I think it's worth the time. It also makes a sturdy mount and adds a measure of safety.
Ron
Ron
#5615
Banned
ORIGINAL: Tseres
Old Tom
ORIGINAL: Peter_OZ
cheers
me
cheers
me
Old Tom
that is what I was thinking, though also have some very fine round tip files that could be used, will try both and see what works.
yup and that is just one side, does not include stab, fin or cowl either!
#5616
Banned
ORIGINAL: rt3232
Pete
The Cub covering thingis done not as nice as I would like but it is just a cub, got the stripe down the sides and have started installing stuff still have to pick up some cub decals for some eye dressing , will most likly have it done and ready to balance this w/e
Bob T
Pete
Bob T
think I was last Sat.
No more progress to date, been a bit knackered of an evening of late. Weekend will get in and do some more.
Well Cubs are still important mate, I have about 40 rivets on my Cub but used small dress makers pins for those, cut them town to about 1/4" long. Tap in a hole using a pin, drop of med CA on the cut down pin shaft then tap it in flush - Voila!
#5617
Got all the Horton servo mounts and servo hatches finished.( I like saying Horton servo mounts.)
Glassing the ailerons and the flaps.Then all the glassing will be finished.
Got tired of running to the hobby shop for small screws so I orderd enough to start my own fasteners business.
Now I 'll be sanding the glass for a few days so won't have much to post about so you new guys its time for you to chime in.
Old Tom
Old Tom
#5619
Banned
Tom,
make sure you wear a good quality breathing mask when sanding that stuff as epoxy resin is nasty stuff.
cheers
Peter
cheers
Peter
#5620
ORIGINAL: Peter_OZ
Tom,
cheers
Peter
Tom,
cheers
Peter
Not sanding epoxy but going toget a mask anyway.
Old Tom
#5622
Got myselfe a good mask you can even wear it for painting.
Sanded the fuse. It took all day.Since I had a new mask, had to try and spray some primer.Couldn't smell a thing.
The fuse looks good, will only need minor tuch up with spot putty.
The picture of the fiberglass hatch cover that, I made 3 months ago and haven't been able to find for 2 days of looking, turned up right where I put it so I can find it. You guys don't have those kinds of problems, do you?
Maybe I'll try to figure out how to make the switch housing next.Do you guys think I should make enough room for 4 swithes incase the plane lasts long enoug to put smoke on it?[sm=idea.gif]
Old Tom
Old Tom
#5624
Banned
ORIGINAL: Tseres
Old Tom
ORIGINAL: Peter_OZ
Tom,
cheers
Peter
Tom,
cheers
Peter
Old Tom
