Reload this Page >
TF GS P47 Build - yeah another bloody one!!
Old 10-07-2014, 06:46 AM
  #10501
Tseres
Tseres's Avatar
Here is the pictures I promissed last night. The teeth get spread out I just bend them back in by rolling it back and forth on the table.
ID:	2038241   Click image for larger version
Old 10-07-2014, 01:18 PM
  #10502
Peter_OZ
Banned
I did the leading edge holes for the .50s in similar manner though the brass tube was simply shapened, worked very well with a clean holes cut. I put it in my battery drill using a jig.
Old 10-07-2014, 02:06 PM
  #10503
rt3232
Ok after work today I went to the shop and dug thru some old stuff and found the brass tube cutter I had made a few years back, so I think that's the way the game will be played, and I have some really hard balsa 1/4 square and I think I can trim it down to fit the holes, so will us that for plug's
Now it is on to the wing to see what has to be done !
cheers Bob T
Old 10-07-2014, 02:45 PM
  #10504
Peter_OZ
Banned
good one mate :-)
Old 10-07-2014, 06:10 PM
  #10505
rt3232
Well got the stab back in place and straight so onward, but trying to pull the plastic covering is a real pain, will not come off as easy as it went on but I will get it
Cheers Bob t
Old 10-07-2014, 07:56 PM
  #10506
Peter_OZ
Banned
try a hair dryer on low heat to loosen it up.
Old 10-08-2014, 05:01 AM
  #10507
rt3232
Been doing that and it is still a pain, it a big bird
Old 10-08-2014, 04:52 PM
  #10508
Peter_OZ
Banned
slowly slowly catchee monkey
No work on my 47 last night, went for a hour and half walk instead.
I did look at it though!
Old 10-08-2014, 05:43 PM
  #10509
Peter_OZ
Banned
Hope to do a bit tonight. Will work out what other jobs to be done.
I did get some very nice 2 ounce carbon fibre cloth a mate of mine that I will use to reinforce the landing gear rails. It will flow around complext shapes easily so should do the job nicely.
cheers
me
Old 10-09-2014, 05:14 PM
  #10510
rt3232
I have only used small bit of C/F in cowls and it was easy to use, after I figured out how to get it to wet out, So will be interesting to see how it goes for you.
Cheers Bob T
Old 10-09-2014, 05:45 PM
  #10511
Peter_OZ
Banned
should be ok, I think the laminating resin to milk consistency so should wet nicely.
I'll post some pics when I do it.
Old 10-13-2014, 03:14 PM
  #10512
Peter_OZ
Banned
G'day Guys,
good weekend of planes. Lots of work in the shed working on the Vampire and the P47.
Vampire is balanced, had to add some lead in the nose but I might pull that out and fit and second 6v battery pack instead. I have opted not to use the UBEC, I don't trust them and they are a single point of failure.
Also if the LIPO did run out of grunt then you have nothing to power the flight controls. My way all is on seperate circuits.
I did some taxi trails along the driveway, seems pretty good though the speedy did get quite warm so might open up slots under the fuz so some cooling air flow can get over it.
I fitted the retracts into the P47 and cycled the gear viola it works!! I also cycled the inner gear doors. They work very well however one hinge broke loose, not a biggy, easy fix.
Took the Astrohog and small Pica Spitfire out on Sunday and had a good morning of flying, good landings on both models. Spitfire is a bit of a handful, espcially landings but I had those dialled in so good confidence boost.
Pic from Sunday.
cheers
Peter
Old 10-14-2014, 04:13 PM
  #10513
rt3232
Glad to hear you had a good W/E of flying, and nice that you are getting things done on the 47.just keep doing a bit every day or so.
Well got all the plastic off still some color spots, and have washed it down with acetone to clean it up but the original balsa-rite is still coming up and leave a sheen all of the structure on the fus is repaired, will wait on the sheeting till I have a good look at the wing, and get that covering off, if the ding repair on the wing goes as well as the fus did I will glass the bird and go with paint so it's going to be a winter project or more. I still have to do the repair on my weeks bipe so been bounsing back and forth
cheers bob t
Old 10-14-2014, 07:05 PM
  #10514
Tseres
Tseres's Avatar
I'm just working on the Camels top wing. No flying weather for over a week now. I know what that is the signe of. Not ready for winter yet.
Old 10-15-2014, 05:03 AM
  #10515
rt3232
OLD TOM your not as old a me
Any way weather hear has been about the sane a little rain but mostly wind hopping all of the leaves will be down this week If there happens to be a calmer after noon I will take the sparky HOG out for a fly
Cheers Bob T
Old 10-15-2014, 05:49 PM
  #10516
Peter_OZ
Banned
just back from out bush, about an hour and hald drive from Emerald. Loads of huge snakes roaming about. Nasty things.
Bob, sounds like you are on top of that repair mate, well done.
Camel is coming along nicely there Tom.
I should be back in the shed for a bit tonight and over weekend. Keep looking at poor old Cub, will have to do a bit on that over the weekend.
Old 10-16-2014, 01:07 PM
  #10517
Peter_OZ
Banned
couple of photos of P47 wing, fixed inner gear door problem.
ID:	2040625   Click image for larger version
Old 10-19-2014, 01:38 PM
  #10518
Peter_OZ
Banned
Weekend report take 2 after RCU locked up.
Saturday spent all day in the shed fiddling mainly with the P47, working out what needs to be done.
Trial fitting of retracts again. Epoxied some spuce in a couple of places to beef the rails and supports up then
checking that the retracts an open and close, lock smoothly and the gear doors lay flush with the wing skin.Ok all good so far.Bit of grinding of timber here and there so I can actually get those retracts in and
out for maintenance etc.
Now to reinforce with carbon fiber. Cut out the cloth, trail fitted, trimmed then mixed up a batch of LY3600 epoxy resin, applied then left to cure over night.
Sunday I took out the Astrohog and Pica Spitfire again but wind was mainly cross wind so only flew the hog which is easy to sideslip in. Spit will tip stall if you try that. So 4 flights later, lots of yakking and coffee drinking was time to head home
Detour to a friends place for lunch which was nice.Back to the shed and a bit more work on the 47.
Sanded down the rough and sharp spots. Will do another trial fitting then onto squirt some yellow chormate primer colour under the gear doors and within the gear wells.
Next job is to fit the ailerons and flaps, fit horns and check movement etc.
It will then be time to put the wing aside and work on the fuz, mainly the cowl fittment and some fiddly jobs with magnets on the access hatches. Make up a fitting for the dummy antenna so it can be removed.I think by that stage it is time to start planning the painting of this bird.
ID:	2041187   Click image for larger version
ID:	2041188   Click image for larger version
ID:	2041189   Click image for larger version
Old 10-19-2014, 02:11 PM
  #10519
rt3232
Looking good Pete, but with your summer coming on I would think you will get more flying time in, at least I hope so.
Well I finally got a bench cleaned off to put the Corsair wing on, and started the inspection of the damaged areas, with the covering on they did not look to bad, but as I started pulling covering and control surfaces there is some major damage leading edge and some sheeting popped off, but no cracked spars so it is repairable, just a lot more work than I originally thought. have decided to go with west system epoxy and glass and paint, just hope I don't pick up to much weight.
weather hear is getting a bit cold, and have just about got all of my out side chores ready for old man winter
Cheers Bob T
Old 10-19-2014, 02:38 PM
  #10520
Peter_OZ
Banned
Bob,
yes mate it is coming along again. Very good to be back on it.
We fly all year round here, weather especially in Queensland is very temperate.
Those wing repairs sound not so bad mate, should be an easy fix for you.
By the way not sure if you and the others are aware but there is a new finishing resin out by Deluxe systems that is water based, cures in a couple of hours and no fumes or toxicity to worry about. It sand back easily and is very light.
A few of the guys I know swear bt it.
BD37 is the product number.
cheers
me
Old 10-19-2014, 04:22 PM
  #10521
Tseres
Tseres's Avatar
Nice going Pete. Flying and getting some wok in on the 47...
I just enjoed one of those fall flying days that come by every once in a while. Didn't get a thing done other the I decompressed from the everyday.
Old 10-19-2014, 07:06 PM
  #10522
rt3232
Hay Tom good you are getting a day or so in. Hear the weather has been the pitts, nice day with wind 15 to 30, then work inter fears, so have been stuck in the shop or yard, I can only stand about an hour at a time picking the D#$%M plastic covering off
Cheers Bob T
Old 10-19-2014, 07:08 PM
  #10523
rt3232
Pete
I will look in to that finishing resin, thanks for the heads up on it.
Cheers Bob T
Old 10-19-2014, 10:37 PM
  #10524
Peter_OZ
Banned
Tom sometimes you need a day to just stare at your navel . . .
no worries Bob
Old 10-20-2014, 05:33 PM
  #10525
Peter_OZ
Banned
no work last night, waqs in a lazy mood and veged out on the couch with the TV and takaway chinese.
None tonight either as girlie has invited me over for dinner at hers. Beats takeaway!
Hey Bob have you tried one of those cover tugger gadgets to put the covering off? Might save a bit of pain in your hands. Tower has them.
