Yellow Aircraft P-38 ?
WI
RE: Yellow Aircraft P-38 ?
full size 52.0ft x 12"= 624" divided by Y/A 101.5" = 6.2089 = 1/6.2 scale close enough to 2" equals 1 ft scale you need to check more dimensions to be sure since sometimes the wing span got increased or the fuse lenght changed to help balance the a/c or aid with engine placement.
tom
tom
My Feedback: (22)
Tom
Thanks, I did the same after I posted here. It turns out to be 1:6.23 per wingspan and 1:6.3 per length. I'll split hairs and call it 1:6.25. It should be close enough for my needs.
Sung
Sung
