TF P-40E in Action
My Feedback: (24)
TF P-40E in Action
I finally got my buddy to recode some videos of my TF P-40E today with me on the stick.
Some specs:
* Wingspan: 64 inches
* Dry Weight: 12 lbs 0.4 oz
* Engine: YS 110FZ four stroke
* Fuel: Powermaster YS 20/20
* Prop: Master Airscrew K-Series 15x8 @ 9500 rpm
* Retracts: Robart 615's with 3/8" Robart RoboStruts (yes, Robart 615's)
* Wheels: Robart 4" Diamond Tread
Flying Conditions:
* Ambient Temperature: 36°F
* Wind: negligible
Here are the videos (crank up the volume):
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/take_off.wmv]Take Off[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/slow_pass.wmv]Slow Pass[/link] - at around 1/3 throttle
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/high_speed_pass.wmv]High Speed Pass[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/loop.wmv]Loop[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/scale_roll.wmv]Scale Roll[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/wing_over.wmv]Wing Over[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/inverted_pass.wmv]Inverted Pass[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/sunset_pass.wmv]Sunset Pass[/link]
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/landing.wmv]Landing[/link] - aah, the important landing with full 40° flaps on those fragile Robart 615's.
* [link=http://www.whitetyphoon.com/rc/tf_p40/movies/landing2.wmv]Another Landing[/link]
Edit: added two more videos
My Feedback: (24)
RE: TF P-40E in Action
Thanks. I just uploaded the second take off, which turned out to be better than the first one. I also updated the high speed pass. The movies were recorded with Sony Digital8 camcorder onto a mini tape. I then plugged the audio/video cable from the camcorder to a video capture board in my computer, played back the movies on the camcorder, and the capture board recorded the movies onto the hard drive.
My Feedback: (24)
Edwin, the plane is balanced per plans. Even with the YS 110 and aluminum motor mounts, I still had to add 2 oz of lead to the nose to get the plane to balance. I have my fuel tank just slightly ahead of the CG and not way up front behind the firewall. This allows the model stay trimmed through the entire flight as fuel is being consumed. The plane is a sweet flyer and lands like a p-cat. By the way, the plane has authentic recessed panel lines and hundreds of both raised and flushed rivets.
My Feedback: (24)
ORIGINAL: Peter_OZ
mate that is excellent, well done. That YZ really humms.
I knew that, it's just the instructions say with wheels down (that's not meant to sound rude or aggressive). I read in another topic that someone balanced with wheels up and it was very very nose heavy and crashed. I'm about to build one myself and this plane certainly is an inspiration along with Peter_oz's P-40 (rip). Anyone got any good shots of theirs?
My Feedback: (24)
My CG is exactly at 3-1/4" when the wheels are up. The plane feels much better in the air when balanced with the wheels up than with the wheels down. Keep in mind that my fuel tank is on or very close to the CG. I suppose if you have your fuel tank way up front, then it might be better to balance the plane with the wheels down.
My Feedback: (37)
IL
Hi Richard
Great video's very scale take off's and Landings. I don't know what it is but landing a plane has always been my favorite part of fling. I was watching the landing video and I notice that when the wheels touched down the tail seem to raise up did you put down elevator into it to make the wheels stick and to produce roll out? Also congrats! on becoming the RCwarbird arf moderator. Doug
VA
Richard,
I've been dying to build this P40, but I keep getting discouraged when reading horror stories about it's takeoff and landing capabilities. Watching your video gives me some courage to try it! I love P-40's, and even though the other TF kits may be easier to handle I'm still thinking about trying it. My local HS has one on the shelf just waiting for me to take it home, and I have an OS 120 w/pump without a home!
Maybe I'll just keep replaying your vids until I work up the courage!
Steve
Steve
My Feedback: (24)
Steve, I think you will do just fine. This P-40 is one of the easy warbirds to take off and land. The OS 120 pumper will fit completely inside the cowl. In fact, the cowl is big and long enough to house a 25cc gas engine. The most important thing about taking off is letting the tail up and let the plane reaches flying speed before attempting to lift it off the ground. I would suggest getting a flight simulator if you don't already have one and practice practice practice.
VA
Thanks for the encouragement Richard. I've flown the P-40 on the flight simulators and I've had no problems. I've got a GP GEE BEE arf, and i've flown it a few times with only one bad landing, but that didn't do any damage. I've read the threads on Warbirds.com, and the P-40 is pretty much considered the toughest of the TF planes to take off and land. I guess I'll just have to judge for myself!
Thanks, Steve
Thanks, Steve
My Feedback: (24)
ORIGINAL: FrankRC1
Do you ever have trouble with your warbird noising over when taking off on grass?
Here are some examples of my take off on grass:
* [link=http://www.whitetyphoon.com/rc/dymond_f8f/take_off.wmv]F8F Bearcat Take Off[/link] - 933K
* [link=http://www.whitetyphoon.com/rc/h9_corsair/movies/TakeOff01.mpg]H9 Corsair Take Off[/link] - 2.0M
* [link=http://www.whitetyphoon.com/rc/kyosho_corsair/take_off.mpg]Kyosho Corsair Take Off[/link] - 1.9M
* [link=http://www.whitetyphoon.com/rc/vq_p40/movies/take_off_17.wmv]VQ P-40 Take Off[/link] - 1.0M
My Feedback: (24)
ORIGINAL: Richard L.
Steve, perhaps you should try the new H9 P-40E when it comes out in the Spring first before attempting to tackle the TF P-40E.
thats a very nice warbird youv got there. i have lernt a fair bit with all your info you post in these forums, thanks.
just wondering does anyone have fottage of the TF P-47 in action since its the one im looking to build.
thanks.
thanks.
