What engine for YA Spitfire
I need to buy an engine for my Yellow Aircraft Spitfire. I am considering between the ZDZ 50cc or the ZDZ 40cc. They have the Zdz 40cc in stock but I am concern that it may make the plane a little under powered. I expect the plane to come in at about 23 or 24 pounds with CG weight included.
I prefer to fly with abit of reserve power. So guys what you think? I fly at sea level, hot and humid
MD
RE: What engine for YA Spitfire
I plan on using the 3W50, long output shaft and plenty of power. Dependable and good rep at Aircraft International.
The Spychalla's use ZDZ40's in their spits and they fly great. http://www.spychallaaircraft.com/
Personally, due to lousy and rude customer service from RCS, I have no intention of ever purchasing anything from them. Not knocking ZDZ, just the distributor.
S1
S1
Here is my friend Lars Y/A Spit. 3-W 50 with Johnsson muffler. Flys great. I would go for a 50 cc.
Here is a link to ZDZ europe, I think their doing ok[link]http://www.zdz-motor.de[/link].
Good luck
Tobbe
Good luck
Tobbe
My Feedback: (75)
MA
I would go with the ZDZ 40. It fly's great with it and you wouldn't lose as much cowl. I've seen many fly with this setup from Top Gun, to Joe Nall, to the Masters.
Beautiful planes Tobbe, what weight does your plane come in at. I looked at the European distributer site and it showed that the ZDZ 60 was 40 euros cheaper than than the ZDZ 50. In that case should I get a 60?
My Feedback: (34)
Build really light in the tail! Toss the plywood and substitute balsa. Toss the stab and build a balsa one. You are going to need to do this to hit 24 lbs. The ZDZ 40 is good. Not a real powerhouse but adequate. I think the 50 uses the same castings as the 60, so it is a big engine that would be tough to hide.
Leo
Leo
Beautiful planes guys... Spychalla, what muffler are you using? I will probably settle for the Zdz 50 with that muffler. With the Euros going up is RC Showcase maintaining their prices?
My Feedback: (34)
ORIGINAL: Harigo
Leo
thanks dennis for the recommendation. I will get in touch with them. I hope they can ship it to Malaysia
