exhaust ideas???
My Feedback: (7)
FL
RE: exhaust ideas???
Hi....LDM Yeah...That kit I returned and they sent me a new one just in case more parts were missing..I stalled Century Jtets retracts it was a tight fit because its the half inch and biger then my top flite this so far its a easy kit to build .I have not installed the sheeting on the wing Im not sure about the flaps intr. kind of comfusing if you are on page 13 The w40 flap is about4or5 mm wider then w15andw 40 ends with a 0 thickeness W41 is about 1/8 of an inch thick????ahhhgggghhh Its about 60% done still have allot of wortk do do here is some pics.
My Feedback: (15)
Looks great !!! I am not starting mine until next winter , to many projects on board so far .
Did century make you custom gear or dose there standard gear work ???
I went over the kit and the plans and building seems confusing at times but the quality and lasor cutting seem real good .
THe outline for the counter balance on the plan is to low , it occurs at the top of the rudder and they show it at about an inch down .The counetr balances in the elevator seem correct .
Any ideas on where your getting yor markings yet ??
Keep us posted , the build looks great so far , good luck
My Feedback: (7)
FL
I think Im getting the markings here http://www.cal-grafx.com/index.htm the sharks mouth Im getting a bike shop to do it for me .
the retracts are not custom but they are the one made for Pica they seem to be the best ones I ever had.I called them he knew about the weight of the plane.
Hey Guys,
I got a hangar 9 p40 and I am putting a T Tiger 75 in it. I don't want the exhaust coming out the side and wondered if yall had a good idea for a scale type exhaust for this arf. The motor is inverted to keep the head in so the exhaust will be on the side. Sure could use some help.
