Testors/Modelmaster Enamel fuelproof?
RE: Testors/Modelmaster Enamel fuelproof?
When you use the clear Lustercoat make sure you spray it on in light coats. If you spray it on too heavily it will take off the paint. I've been there already.
I used satin polyurethene from Home Depot and it worked just fine. I believe the brand was Minwax. The can had a fan nozzle, and that made a huge difference. I only put on two light coats and it's still holding up fine. I hate Lustercoat.
