CMP Zero 120 w/ YS 120
FL
RE: CMP Zero 120 w/ YS 120
Hi Sean.
I got also a CMP Zero 71". The instruction aren´t clear regarding how to glue the two wing half. They mention epoxy and that´s it. Would you like to tell how did you do join the two half and if you reinforced the joint?.
Thank you very much for your assistance
Renato
Renato
My Feedback: (18)
dear sean
beacase of your beuty zero i order one--thanks
i cant wait to how it will be with my new ys 140
i like my planes with over power becaus the heat in israel now its winter with 23 c and in sumer its 40c
very hot
when ill get it ill let you know
is the wing is balssa or foam and if it with flapps
udi maman
israel
very hot
udi maman
israel
MI
ORIGINAL: a6m5zeke
Hi Sean.
Renato
Hi Sean.
Renato
#31
MI
ORIGINAL: udi maman
dear sean
my zero crashed today i had a fail safe while i did a split S and i got it oh god what a crash the zero was 7 days old
udi maman
israel
ther was saito 180 on it beacause i didnet got the ys 140 from omp yet
dear sean
udi maman
israel
Oh man, I am extremely sorry to hear that. Fail safe, there's nothing you can do about that, except for switching channel. At some fields, some channels are better than others. I am on PCM for all my planes, and I still get mini glitches here and there.
Are you gonna get another one? This thing is such a joy to fly. It flies so much like a pattern plane. I've been doing thinsg like square 8, rolling circle, flat spins... If it weren't for the small rudder, I'd try some 3D with it.
#33
VA
I have both the GSP Zero and the Platt Zero still in the box. My GSP is over powered with the OS108 but not greatly. I plan to put a OS 160fx in the Platt Zero hopefully less than 20 pounds. I would want a little more motor in a 17 pound Zero. I suspect the YS 120 and OS 108 are close in power. Platt recommends the OS 108 at 15 pounds.
The Zero is a great flying plane. I will not get to the Platt Zero until next winter. Building a IMP Claude currently.
#35
MI
I have rpm data for all 3 engines:
OS 108, Slimline Pitts muffler, APC 17x6, 15% nitro: 9400 rpm
YS 120 NC, APC 17x6, 20/20: 9500 rpm
YS 110 FZ, APC 17x6, 20/20: 8900 rpm
Could be my YS 110 is weaker than the rest. But the OS 108 is awefully close to the YS 120.
Frankly, I think 108 is enough power to fly the Platt Zero, even if it's 17 lb. But when it comes to scale plane powerplant, horsepower is not my primary factor. Rather:
1) weight necessary to balance the plane without re-engineering the hood or clogging up the firewall with lead
2) ability to swing a prop large enough to look nice.
So, frankly, a short-nose design such as Zero at 17 lb, you will need a gas engine to balance it, or a heavy large engine like Moki 1.8. And you want a nice big 16x8 3-blade prop, so OS 160 or Moki 180 would be in the correct torque range for it.
Udi,
Don't go back to FM. If you get interference on a channel on PCM, you will get interference also on FM. The difference is, you don't know what it will do when you get hit. At least w/ PCM, you can program to neutral-idle, so damage to the plane, property, and people is statistically reduced.
I would try changing channels. It's cheaper to get new crystals than to get new receivers. And don't fly too close to other pilots, as 2 transmitters in close proximity will produce a totally different radio wave.
Udi,
#38
MI
ORIGINAL: mikejdad
What is the number for the Robart retracts....Thanks..
#40
IL
HAS ANYONE IN THIS THREAD BEEN ABLE TO FIND A COCKPIT INTERIOR FOR THIS PLANE , i JUST GOT ONE MYSELF AND WOULD LOVE TO SCALE IT OUT AS MUCH AS POSSIBLE , I HAVE A REALLY NICE FULL FIGURE PILOT THAT NEEDS A HOME LOL !
#43
IL
Hey I found a cockpit interior for this plane that fits it perfectly from www.vikingcockpits.com of course it has to be assembled and painted , but a great quality product
