 Hanger 9 P40E Warhawk >
Old 04-21-2005 | 12:25 PM
Default Hanger 9 P40E Warhawk
I'm currently building a Top Flite T-6 Texan from a Kit. I'm a ways away from being finished with it, and can't wait to get a warbird in the air. So, I've decided to go with an ARF for now--to quench my thirst until I get the Texan in the air. Also, to give me some experience flying warbirds before I put all of those hours of work in jeopardy . My question is this. Has anyone out there flown this plane? What experiences have you had with it? Ground handling, landing speeds, etc. I'm probably getting one this month. I'm putting a Saito 100 on it.
Thanks.
Old 04-21-2005 | 12:41 PM
Default RE: Hanger 9 P40E Warhawk
read the forums do a search
Old 04-21-2005 | 02:01 PM
Thanks for your help. Sorry to have bothered you on your otherwise busy day.
Old 04-21-2005 | 02:15 PM
seanychen's Avatar
Sorry about it... now I understand your other thread. I think Tim meant it in a nice way. Several people have finished it and I know someone has flown it with flight report in the ARF forum just today. I don't mean to just tell you do a search, but there's no easier way than for you to head over to the ARF forum and look for the H9 P-40 that has like 6 pages. The flight report is on page 6 I think.
Old 04-21-2005 | 02:26 PM
Thanks sean. I've read all of those pages. I was just looking for someting more. What, I don't know, just researching.
Old 04-21-2005 | 07:47 PM
ya i didnt mean it in a bad way i am building one with a os 90 fs. Need to do the muffler so it does not stick out the cowl that is not cool
Old 04-21-2005 | 09:03 PM
One guy in another thread used automotive fuel line, but he had a pumped engine. Wouldn't work too well on one that relied upon muffler pressure for fuel delivery.
Old 04-21-2005 | 10:33 PM
seanychen's Avatar
ORIGINAL: timothy thompson
I believe for your OS, the best way to go is Performance Specialist muffler with a 90 deg elbow.
OS exhaust port slants backward a little, so with a 90 deg elbow, it will direct the exhaust pipe to the bottom center of the cowl.
Old 04-21-2005 | 10:48 PM
proptop's Avatar
My Feedback: (8)
I've been wondering if one could purchase some metric tubing nuts from an auto parts store or something? You could make a header out of the mild steel fuel tube, put a flare on the end, and you'd have a header as long as you need. All ya gotta do is bend it to whatever shape you need.
I did that on an old Saito .80, but I just used the header that came with the engine and brazed on an extension. I also brazed a pressure fitting in the tube that had a 45 degree angle on the end facing the oncomming exh. gasses. I got a little bit of tank pressure with that set-up, but not as much as with the stock muffler...
