top flite p-47
top flite p-47
hi. I am about to begin building this plane. What do you guys think about the weight when using an os 120 p and glassing the plane. cjm retrakt.
This is my first skratch built plane. Every hint and tips about building this plane is aprichiated.
RE: top flite p-47
If so i be happy. Do you have this plane? picks.Or do you have any links to sombody who have built this plane. Not much info on the net.
RE: top flite p-47
I did that exact set-up with scale cockpit, dummy radial engine. CJ retracts os120 pump, remote glow slaved to throttle servo. Glassed airbrushed, rivits, panel lines. 13.5 lbs dry
Kirk
Kirk
My Feedback: (35)
CA
RE: top flite p-47
ORIGINAL: kimfrode
http://www.rcscalebuilder.com/forum/...ics.asp?FID=26
randy
KY
RE: top flite p-47
I have one that is glassed with rivet, panel lines, bomb and drop tank, cockpit, dummy engine, retracts, flaps, powered with OS .91 Surpass and weighs 10 1/2 lbs. Flys great for scale but not a rocket vertical. I had to add several oz. of weight to the nose for a good balance. This is my favorite airplane and flies like a dream! Try to keep the tail as light as possible and your have a great flier. I have built 2 of these planes, if you have any questions, let me know, I might be able to help you.
RE: top flite p-47
Thanks so much. Just started building the jug. I post some picks soon.By the way, i am looking for some videos of the jug. Do you have any or do you know some internett sites whit videos?
RE: top flite p-47
ORIGINAL: green river rc
What's the reason for 2 servos?
ORIGINAL: Blue_Moon_
just remember to get dual aileron servos into the ving instead of one single...
thrust me.
thrust me.
