New 81" P-47 ARF coming from Hangar 9
#3351
NM
RE: New 81
I am trying to build a carrier for my P-47 and I remember a while back someone posted pictures of a PVC carrier for their H9 P-47 that I can't seem to find. They had a German paint scheme on their jug. Does anyone know the forum/post/member?
D
D
#3353
RE: New 81
If it was G-Pete's P-47 in German markings you are thinking of I doubt you will find anything on this thread as Pete's P-47 was not a Hangar 9, it was a Top Flite.
As the Top Flite is a one piece bolt on wing I think the plug in wing on the Hangar 9 will require a different set up all together.
#3354
NM
RE: New 81
Found it way back on this thread, page #101 post #2513! It is G-Pete (I think he has both a H9 and TF P-47)
http://www.rcuniverse.com/forum/fb.asp?m=6659396
D
D
#3356
VA
RE: New 81
After cutting some small holes in the wing to get a better viewof the two hinges I could not see, two of the three hinges on the right aileron did have a block made from 1/8" balsa wood behind them. Total hinge support 1/4" balsa. The blocks were about a 1/4" bigger than the hinges. I used radio south hinges in the build. I talked to Horizon and they requested I return the wing to them and I shipped it out today. Will udate when I here back from them.
JT
JT
#3357
RE: New 81
I've had this plane since it first came out,and the only thing I'm going to change now are the retracts.I've hAD NOTHING BUT TROUBLE with these,so I'm going to go with Robarts.The servos[JR 791's] either burn out or the gears strip.I'm fed up.Tom[:@]
#3358
1 Post
RE: New 81
hi
can anyone tell me if sierra do replacement parts for their gear for this plane ,my mate has bent his on the top of the leg which goes into the unit ( if you understand my crap description) had a look at the web site but doesnt really mention spares
thanks
andy
thanks
andy
#3359
RE: New 81
Hi Andy, I'm sure they do as when I bought those retracts Darrel said to give him a shout if I needed any bit,s ie, torque links, axels and so on, so I would think Martin will get a new strut no problem.
#3363
RE: New 81
ORIGINAL: Doomking
Are the Robart Retracts for this plane a ''drop in '' replacement or you have to make some serious mods?
Just wondering...
Just wondering...
#3364
RE: New 81
I put Robarts in mine. Needed a little time with the Dremel tool, but not much. Also have to relieve the opening just below the retract mount to clear the airlines. The Robarts are a MAJOR improvement. I haven't yet figured out how to mount the gear doors with the Robarts installed. If this issue has already been covered in this thread, does anybody know the time stamp or post number?
Thanks in advance.
Thanks in advance.
#3365
My Feedback: (38)
RE: New 81
Thanks for the reply.
For all the pilots that are still flying the plane with stock retracts, how often they bend or need attention?
I have couple of giant scale warbirds with Sierra and Robart in it.
Could I just go by with the Hangar 9 retracts or I need to go out and buy Robart right way in order to land the plane without issues?
Happy Holidays.
Happy Holidays.
#3368
My Feedback: (48)
RE: New 81
Lifer,
Here's how I did the gear doors. Struts are the regular Robart 1/2" for 4-5" wheels. If I had gone with the ones Robart makes for this plane they wouldn't stick out of the wheel wells quite so much. The stock wheels look like crap so I also put 4.5" wheels on mine.
Doomking,
It will cost you $120+ just to buy the JR791 servos to make the Hangar 9 retracts work. You'd be much better off putting that money towards a set of Robarts.
Joe
Doomking,
Joe
#3370
RE: New 81
Hi all, and a late marry xmas.
I fly my p47 with stock retract,and its givving me no problems what so ever[8D] I must admit that one has to do a proper landong every time,else I am dam sure that it vill buckle and bent [:'(]
I will try to put in a link to You tube of me flying her. If you like, you can skip the Helicopter part,that me at a beginner stage. [&:]
Feel free to coment if you like.
Best regards, Tomas. http://www.youtube.com/watch?v=2bCQeFL6Wog
#3371
RE: New 81
Hi Tomas, merry Christmas to you and a happy new year when it comes. That was lovely flying and if you keep landing like that you will be using that undercarriage for a very long time.
#3372
RE: New 81
Hi Simon, and thanks.
I found ,that the P 47, is a werry easy Warbird to fly and land. I have been flying all sorts of Warbirds, and this one is by far,the best. [8D]
How is yours holding up ?
BRG. Tomas.
BRG. Tomas.
#3373
RE: New 81
Hi Tomas, I sold mine after 30 or 40 very enjoyable flights and I am now busy with a 1/5 scale FW190 and a YT International Hellcat.
#3374
RE: New 81
Hi Tomas,the other problem I had with this gear are the stock wheels.Ive had three tires split right down the center of the tire.I bought two Robart tires and hope they are better than H9's. This is still a great flying WB,sad they stopped making it.I know they had brought it back for a short time and said the reason they stopped making it was because not enough people wanted to pay the price. Tom
#3375
RE: New 81
Hi Prop Wash.
I also found that those stock wheels was no good at all,so I replaced them with Robart 4",they just fit nicely in the wheel bay in the wing.
I whonder if that seice of those wheels are true scale ?
