F6F Hellcat ARF (China Model Productions)
#31
My Feedback: (13)
Lomcevac54T,
I used the Sierra retracts made especially for the ESM F6F. There are several size F6F retracts that Sierra produces for this type of airframe-these are the ones for the ESM model.
http://www.sierragiant.com/prod42.html
Here are the retracts you need to use on the ESM F6F. They are very robust and do an excellent job of taking the bounces out of your landings. They are not cheap...but worth every penny you spend...believe me, they are first rate, very well made and the service these folks give is very good.
Soft Landings Always,
Bobby of Maui
Bobby of Maui
#32
My Feedback: (15)
No offense but this is the CMP Hellcat not the esm , the biggest difference is the quality and cost .
The sierra are no doubt fantastic retract but they average almost 40% higher then the average cost of this plane .
From a value standpoint with proven field experience the esm 3.5 work well from what I am being told .
The ones below are new , they are rather for a 30 lb aircraft .
*RC Lander HD P-40 Style Electric Retract Landing Gear
[RCLHDP40] Regular Price : $299.95
Sale Price : $179.95
Factory Warranty, Replacement and Direct Exchange, for USA Buyers,
administered out of our Michigan, USA Warehouse for your convenience
RC Lander Heavy Duty Large Scale
Designed for Large Scale Size P-40 Style Planes
(or similar models)
90 Degree Extended with 90 Degree Rotation on Retraction
Free Shipping* and Stocked in USA
Complete with 2 Main Retract Units, Struts,
Tires and 2 way Connector Cable!
NOTE: Modifications to wheel wells and fuselage will be necessary as these units
are not a simple drop in replacement for the stock mechanical retracts
Do not ever exceed 6.0 volts
Do not continually cycle during testing to prevent over heating
Lubrication should be avoided as
contamination of the the electronics can occur
(or similar models)
#33
My Feedback: (60)
AZ
You talking about these from sierra? I thought they may not hold up to this size bird.
http://www.sierragiant.com/prod30.html
