Reload this Page >
Prop Size for OS 91FS Four Storke on H9 P51
Old 08-31-2005, 10:34 AM
Ksubram
Default Prop Size for OS 91FS Four Storke on H9 P51
I just finished the Hangar 9 P51 60 size with an OS 91FS Four Stroke. Can anyone suggest what would an ideal prop be for this setup. Any help would be appreciated.
-Kris
Old 08-31-2005, 11:43 AM
Richard L.
My Feedback: (24)
Richard L.'s Avatar
Default RE: Prop Size for OS 91FS Four Storke on H9 P51
13.5x8, 14x7, or 14x6, which ever gives you a ground rpm of around 9500. The 13.5x8 prop will give you the most speed at the expense of diameter.
Old 08-31-2005, 04:25 PM
RDonovan
Kris, I'm running the same combination with an APC 15x6. Flies beautifully.
Richard
Old 08-31-2005, 11:31 PM
daw
daw's Avatar
I've got an APC 15-6 on a Bearcat 9.5lbs, Corsair 10lbs. and on a Sea Fury 12lbs all with flaps. The At-6 without flaps at 8.5lbs is better with a Graupner wide blade 14-7. The 15-6 pulls better but has less speed still they fly well at 3/4 throttle. The At-6 is fast and the 14-7 wide blade Graupner acts as a brake when slowing for landing. All the planes have OS 91 4-strokes.
Old 09-01-2005, 09:59 AM
Ksubram
Thanks guys for the quick reply. Sounds like the 15x6 is the way to go. Will give the 15X6 and also 13.5X8 and see how that goes.
-Kris
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
