Engine advice
Engine advice
I currently have an OS 61 on my TF spit and the weight has come in on the heavy side (9.75 lbs all up). I would like to swap my 91 FX from my large J-3 and put it on the spit and put an ASP 1.08 on the J-3.
My concern is the ASP as I know nothing about these engines other than they are more than 50% cheaper than the same size OS engine, any input as to the quality and longevity of these engines would be greatly appreciated.
As for the spitfire, I was wandering if anyone out there is using the OS 91 and if so what prop combination are you using.
Cheers
Dave
Cheers
Dave
RE: Engine advice
Thanks for the post, I've stuck with OS on all my airplanes so far and I think I will do the same for the J-3, at least I know the quality I am getting.
Cheers
Dave
Cheers
Dave
