Wing Loading on Warbird?
MD
Our plane at work is 101" (1767 sq " ) at 60lbs with a 3W75, a lil' heavy but flyable, climbs out at just about 45 degrees. I throw that number in just so you can get an idea that with models, we're not even getting close to hi wingloadings.
I'd have to agree, very light indeed !
Mike
Mike
My Feedback: (7)
Can you tell us a little more about which 'bird you're looking at? It'd help. Sounds VERY LIGHT if you're talking about the "typical" low-wing, Pursuit or Fighter types. Not bad for a L-4, for example, maybe even a little heavy.
Sounds like a bit of a "challenge" to fly in windy/gusty conditions if it's a typical fighter type.
WI
That must be a Desert Winds Me109 since the large engine 75cc !
The Meister will fly very well on a Q-42. But has never stopped one from sticking in a large engine!
SO WHAT IS IT?
SO WHAT IS IT?
ORIGINAL: SpitfireMKI
What does "flies like a trainer" mean when referring to a warbird ?
"This means it flies like a 2x4 rather than a Brick" -- Very funny!
I have a Meister ME109G that is almost ready to fly. I researched this plane quite a bit before buying it and corresponded with others who have flown this plane, including Lenny Smith who has built and flown a lot of these. My understanding is that the flat bottom wing of the Meister design generates a lot of lift (and drag), which allows the plane to fly relatively slow and makes landings easier. Of course this won't help the ground handling and I have been warned that takeoffs and landings can be tricky, especially on a paved runway.
-Ed
-Ed
MD
I've got an LT40 with early WWII Stars on it, hmmmmm, seems to me it flies just like a Meister Me109......[:-]
Maybe I should put crosses on it ?
Hehehehehehehehehehe !
Come on guys, the fact is a trainer flies like a trainer because it is a trainer, would it not be better to say the "Me109 flies like a Sport low wing" ? because that's what it is except it's real big ?
Goin' fishin' !
S1
Goin' fishin' !
S1
