CMP 73" P-40 kit bash
My Feedback: (15)
RE: CMP 73" P-40 kit bash
Wydah , I plan on useing flite skin on mine , I just did this on a Seafury and the flitetskin is so thin , warp resistant , and when you add ribs its as strong as carbon fiber .
I am very curious on the hindge set up , did you add an internal crossbrace in the wing so that the hinges had a place to catch ?
Again , thanks for the answers you did a great job
I glued 3x10 mm hard balsa under the edge of the wing between the ribs and cut a hinge slot diagonally down so that the hinge point ended up at the skin. The flaps are built up 2 mm balsa with 3 mm ribs and a 3x12 mm leading edge beam. I used 2 mm balsa between the ribs to make a box structure in the forward 1/2 so they're pretty stiff and very light. I used three heavy duty pinned Du-Bro hinges on each flap.
Not much progress. The flaps are connected to the servos and operate nicely, I also cut out the cockpit sides and made balsa ledges and a cardboard instrument panel shield. Then I mixed some paint and brushed it on. I'm not going for scale perfection, just a plane that looks right to me. Eventually I'd like to recover and paint the plane in a grey/green british scheme.
I ordered parts to make my own belt reduction-drive to drive the big Soloprop so that will be interesting.
#32
It is quite serious looking.
The gear ratio reduces the prop RPM at 1300 W to 4160 rpm, so I shoul dbe able to spin the 20" three-blade. I have pinions to achieve a slightly lower and slightly higher gear ratio as well.
#34
Hehe. I only fly electric.
I have an ESM (KMP) Spitfire that I have converted to electric. The P-40 should be lighter than the Spit:
http://www.enrarot.net/videos/spitfire/spitfire06.wmv
http://www.enrarot.net/videos/spitfire/spitfire08.wmv
The reduction drive fits in the nose perfectly. The motor is conveniently positioned behind the intake on top of the nose so cooling should be good. I may have to add some fibreglass around the box.
#36
My Feedback: (37)
TX
The motor and gear reduction unit looks great! I have never flown electric, but after seeing and hearing the video of your Spit, I am inspired!
Any chance you could post templates and a parts list for the power unit???
#37
If I were to build another belt drive I would choose smaller pulleys to save weight, maybe try plastic pulleys instead, and make the assembly a little smaller. I made it tall and used a long belt to get the motor positioned by the air intake. I used big pulleys to make sure lots of teeth were engaging but the pulleys are heavier than I thought they would be.
http://www.sdp-si.com/
Parts:
Shaft: S40PX0MHG6M-100
Belt: A 6R53M067060
Pulley: A 6A53M028DF0606
Pulley: A 6A53M045DF0606
6x12x4 mm ball bearings.
Here's a CAD drawing of the parts: http://www.enrarot.net/images/belt01.zip
Later I might make a counter-rotation gearbox for my Spitfire using both gears and belt reduction.
Parts:
Belt: A 6R53M067060
#38
My Feedback: (37)
TX
THANKS FOR SHARING!
Sorry to take so long to thank you. I looks really innovative and I plan on doing the research this weekend.... I am having a problem opening the CAD drawings, I can't seem to figure out what opens a DXF file! Can this be converted to Adobe or something common?
#41
Mine came with a black spinner that looks totally wrong for a P-40.
I've been away for a few days so I haven't made any progress on my P-40. Today I spent ten hours at an airshow. http://www.bardufossairshow.com
#42
I think the real cmp p40 came with a spinner while the copy didn't. I have the copy so, will need to get a spinner.
The 4.5" spinner looks real good in the picture, is the gap very noticable up close.
#44
The 4.5" spinner leaves a noticeable edge (~1/16" wide) around the front of the fuselage so I would only use it temporarilly on mine. Since I have fited the gearbox and Soloprop soon than I expected I will have to make a new fibreglass spinner anyway.
#47
Be glad you're not living in Norway. The plane costs $500 here and that doesn't include the $100 shipping (cheapest option fromt he norwegian dealer, inside Norway).
#49
Here's a video I shot at the airshow yesterday if anyone is interested. Sadly the battery in my camera died just as it was getting interesting so that's why it stops so abruptly: http://www.enrarot.net/images/flyste...6/msms2006.wmv
