how do i make the canopy move for and aft
hi i could do with some help as im not shore how to do it i would like to make my canopy on my h9 corsair move, so it slides forwords and backwords is there somthing i can buy or is there a easy way to make some thing that will acheive this
thanks for any help
thanks for any help
It will take some work, whether you make all the parts yourself, or start with some commercial parts. Dynamic Balsa sells canopy tracks that basicaly is a Plastruct I beam that slides in a slot cut in oneside of a brass rectangular tube. You would have to let the brass into the side of the fuse, and glue the top surface of the I-beam to the inside of the canopy. Study full size Corsair pix for how the tracks run. If you want to go further and make it servo operated, that will be additional complexity.
yup that is the i was thinking it will have to go on a rail or the other way is to make a small slot in the side of the fuzz with a micr servo sat in the fuzz behined the cocpit with some sort of linkage conected to the canopy so it travels up and down the small slot and as to inflight to stop the canopy lifting with the air flow i thought about a thin magnet like the ones you put on your fridge
i have done a small sketch what you think
Smokingtommy,
Take a look at the TF Group Build thread, I've posted a video and pics of what I came up with on Top Flight corsair canopy (starting on post #847). Maybe it will be of some help.
yup thanks just checked them out cool the reason i wanted to do this to the H9 is becauce you spend so much tine putting a nice copit in then when you put the canopy on you cant see it unless you put your nose right up to it and peek though the windows you may as well have tinted windows
