H9 Spitfire Build
#176
RE: H9 Spitfire Build
Kelvin,
I went to your wedsite. How do I order the Spit exhaust? It isn't listed. The link you have in post #168 doesn't work with my ancient computer systems. You can email me at [email protected]
Sparky
Sparky
#177
CO
ORIGINAL: keleocast
I dont know about the cowl issue, I guess we will find out the hard way. I dont know why you guys dont like the square cowl, if you did some searching on the internet for pictures of Spitfires you would find that a lot of the old spits had the square cowl, or the cowl with the eyebrowl.
Kelvin
Kelvin
Related question: are you considering making a scale Mustang exhaust for the new H9 1.50 size P-51 and the Saito 220? Now that this ARF is on the shelves, this is probably a match-up we're going to see more of!
Saw on your web site that you have a slimline Pitts style for the 220, which is a likely choice for this combo, but I may go with a scale exhaust should you make one available.
Bo
#178
My Feedback: (25)
ORIGINAL: Rip n Bank
Kelvin,
Bo
ORIGINAL: keleocast
Kelvin
Kelvin
Bo
Kelvin
#179
NY
I am building the H9 Spit and putting the FA-100 Saito in the plane. I am trying to make the cowl as permanent as possible and have installed a remote fule filler and an extension on the high speed adjustment. I do not know where to route the crank case vent tube? Do a lot of fluids come out of this tube. This is my first experience with a four stroke engine. Where would you route this tube. Also how do you access the low speed adjustment? Is it necessay to adjust the low speed often? Any ideas on where to route the receiver antenna also would be appreciated.
#180
CO
ORIGINAL: lazaras
I also made my H9 60 P-51 cowl as "permanent as possible," also. I also added the remote filler, and have an extension on the high-speed mixture adjustment, as you do.
You do need to vent the crankcase to the outside, preferrably at the bottom of the plane along the firewall. Enough comes out of it that you don't want it depositing inside the cowl! Drill a 1/4" diameter hole in the bottom center of the cowl along the firewall, and hold the tube in place, with maybe 1/4" extending beyond the cowl, with a small U-clamp on the firewall.
Just like the hole for the high-speed needle, A CAREFUL set of measurements will allow you to drill a ~1/4" hole aligned over the idle adjustment screw. That will allow you to slide in a narrow screwdriver and turn the screw. You will adjust this periodically as the engine breaks in, or as it naturally falls out of adjustment.
I route my receiver antenna in an antenna tube down the interior length of the fuselage (all my glow are 60-size or larger, so there's plenty of room). Keep it as far as possible from tail surface metal control rods, and you shouldn't have any interference problems. At least, none of my planes exhibit any...
Bo
#181
CO
Oops! Man, it's a Monday and I need more coffee!
Regarding that 1/4" hole for the crankcase vent: you should already have a MUCH larger hole back there anyway for exhausting the engine cooling airflow. I think the rule of thumb is three times the area of the cooling air intake in front of the engine.
Simply drop the crankcase tube of of that large air vent (I still clamp mine on the firewall).
#182
Banned
1 Post
ORIGINAL: lazaras
http://www.rcgroups.com/forums/showthread.php?t=597267
The crankcase vent should just be left to hang out of the hole in the bottom of the cowl. You will need to drill a hole form the idle adjustment.
Dennis
#183
Banned
1 Post
Had three flights on the Spitfire today and used the flaps for the first time. Dont rearly need them at my field but wanted to give them a go. When deployer she balloned quite aq lot so will have to mix in some down elevator.... I was wondering how much to put in. Has anyone done this yet
Dennis
Dennis
#185
My Feedback: (89)
[8D]It is not a spring, but a metal stop...it goes to the side that the set screw is on the moveable side...the set screw adjusts the angle that the strut sets...confusing...do you want a picture ????
Codimasta
AMA 11269
Codimasta
AMA 11269
#186
My Feedback: (15)
LA
Hey Guys,
I have a question. How much clearance is there from the exhaust port to the cowl with a Saito 100 installed? I am considering a header/muffler coming out next month that may fit inside the cowl and route the exhaust out the bottom. Any help is appreciated. Thanks.
Jim
Jim
#187
Banned
1 Post
Jim
There is very little clearance indeed. I have several pictures that might help you over on my detailed build thread over on RC Groups at this link
Dennis
www.densplanes.co.uk
Dennis
#188
CO
ORIGINAL: Biker02uc
Hey Guys,
Jim
Hey Guys,
Jim
Given that the cowl designs of the H9 Spit and P-51 60 are similarly narrow, and both slope upward at the "chin", I doubt you would have any more space there than I do on my H9 P-51 with its Saito 100.
On that plane, measuring on a straight header pipe, there is 1/2" along the bottom of the header pipe from the cylinder head to the cowl, and 1-1/8" along the top of the header pipe to the cowl.
Bet the Spit is very similar.
Bo
Bo
#189
My Feedback: (15)
LA
Thanks for the information, Bo. That seems a bit tighter than I remember. I had the P-51 60 size at one time. Now I have the 1.50. Looking at the front of the spit without the cowl, it doesn't seem the engine would come outside the box width. All I need is about 7/8" for my header to fit.
Thanks again.
Jim
Thanks again.
Jim
#191
Has anyone a picture of a H9 spit where you have used flat clear spray? I really like the H9 spit, but Im not thrilled about that glossy look.
#193
My Feedback: (12)
CA
If I were to get air retracts from Robart, which ones would work in the H 9 Spitfire? I'd probably get struts and all.
Also what kind of paint do you spray on to make the finish a little flatter and fuel proof. I know this question has been asked a million times. I can't find the answer.
#194
AR
I can't help with the retract question, but try this here stuff for a flat topcoat.
It's Top Flite (Monokote) spray laquer. I've used it a time or two and it holds up well. I've heard that it reacts with sunlight and turns a bit darker, but so far, I can't attest to that.
http://www2.towerhobbies.com/cgi-bin...p?&I=LXCZW4&P=
#195
This is good stuff. It holds up well in my experience and will make your plane look alot more like a plane than a shiny new x-mas present. It will however create darker spots in the sun. It happened to my .60 size zero. At first it annoyed me but it actually made the plane look weathered.
I have had good success with it and all I run is 30%.
#196
Nice. I would like to see a picture of a plane with this stuff on. How much does it flatten the surface? I think the H9 spit is a bit too shiny.
#197
NY
I have finished the Spitfire and installed the receiver. I am using all JR 821 servos and a 791 retract servo. I have a JR7202 7 channel radio with a JR720 rx. I am using a 4500 mah 6 volt battery. When I turn it on almost all of the servos make noise as if stuck. Even when I release the servo arms the servos make noise. This is on the work bench and at different freq. This is also set for ppm modulation.
Do you folks have any idea why this is happening? If this is the incorrect forum for this post, I apologize. Happy new year.
#198
Banned
1 Post
ORIGINAL: lazaras
It might be that your servos dont like 6 volts (5 cells) some don't like 6 volts
Also the JR821 is a digital servo and most if not all digital servos make noise all the time they are doing this to maintain a true centre position.... Accepting the noise do the servos respond properly to stick movement on your TX ?
Dennis
#199
NY
Dennis,
The servos react just fine to control movement. I have a Nexstar that uses the same servos and makes no noise. I have tried the 1100 mah 4.5 volt battery and still get the chatter. I am using the large capacity battery in case the retract servo gets hung up. Do you think all the chatter will cause the battery to drain very quickly?
Laz
Laz
#200
Banned
1 Post
ORIGINAL: lazaras
Dennis,
Laz
Dennis,
Laz
on page 15 post 216.
This will always mantain one battery for the flight surfaces.
When you get the noise from the servos are they all connected to the plane because if not a digital servo with nothing to pull against will chatter as it trys to centralise. Dig Servos do uses more power but no need for 4000 mah
