Reload this Page >
P-40 on Realflight G2
Old 01-30-2003, 05:06 AM
sparky925
Default P-40 on Realflight G2
Anyone have or willing to create a accurate flying P-40 1/5th scale on RealFlight G@?
Would like to be able to practice a little, with a setup that is tested.
Tony
Old 01-30-2003, 02:45 PM
Skypoint
My Feedback: (7)
Hi,
The recently released RF G2 Volume four has the P-40, which you can edit to the size you like. I think it's the best add on of the bunch. :thumbup:
Old 01-31-2003, 12:05 AM
sparky925
Default p-40 on g2
Well ive seen that, but ive never flown a war bird, was hoping some would have 1 set up as realistic as possible,
I know that G2 is good, but it still is not set up with the BAD tendencies of some planes..
Tony
Old 01-31-2003, 12:25 AM
Juice
If it's the BAD tendencies you want, that's easy...
1) Increase the weight of of the fuse, wing, h stab, v stab (effects are obvious)
2) Put some wash-in on the wing (to make it snap when you're too slow)
3) Move the CG back (for unstable flight)
4) Have someone change your trim setting while you're not looking, then fly.
I do these quite often, while trying to learn how to fly my (still unbuilt) Corsair. You can do a ton of things for BAD tendencies. One more thing I haven't tried yet it to move the landing gear location backwards, to experience nose over tendencies.
Juice
Old 01-31-2003, 12:50 AM
sparky925
Sure sounds good, im just leary of a NEW plane, not to mention first war bird
just thought someone might have 1 set up like theirs accually fly
Tony
Old 01-31-2003, 03:04 AM
barnyard
I increased the size of the one I have to about the same size as my Pica P-40 (1/5th scale or therabouts). The problem is in engines available to use with it.
