Multi-Bladed Prop Source >
Old 01-30-2003 | 05:46 PM
Default Multi-Bladed Prop Source
I'm looking for a good source for a 4 bladed prop. I wanting to put a 15.5x12 4 blade prop on my TF P-47. The only prop I have found that size is an APC prop. I don't think that an APC prop would look good on the front of this plane. It doesn't appear that Master Airscrew makes a prop of this size in 4 blades. Does anyone know of another source of props that would work well?
Old 01-30-2003 | 10:54 PM
Check Zinger Out. Also check out Frank Tiano Enterprises. G
Old 01-31-2003 | 01:08 AM
My Feedback: (21)
Default 4 bladed props
Check out AirMagic, he makes PK 4 bladed props.
Clay
Old 01-31-2003 | 02:48 AM
twinman's Avatar
Default 4 blade props
The Zinger site for four blades is http://www.zingerpropeller.com/4_bladed_propeller.htm
Good Luck
Old 01-31-2003 | 05:12 AM
Thanks for the info guys. Looks like that four bladed zinger might do the trick. It's much more scale looking than the APC prop.
Old 01-31-2003 | 03:58 PM
rsallen13's Avatar
Or try these guys for a bolly prop.
http://www.falconhobbies.com/
Old 03-02-2003 | 11:46 PM
Here's a company that makes JUST what you need:
(a variable pitch adjustable 4 blade)
http://www.eam.net/Varioprop/Vario%20Prop.htm
Old 03-02-2003 | 11:50 PM
My Feedback: (8)
You might also look into Graupner props.
