Building 2 Balsa USA Nieuport 28
FL
Nick and the Snake have started new projects together.These are balsa USA Nieuport 28.Here are some of the picts.These are 3 day progress.
RE: Building 2 Balsa USA Nieuport 28
Wow, fantastic R101. Very nice work indeed!
Mine weighs @ exactly 7 lbs. without engine and cowling, so we're right in the same ballpark.
I see you have your 'N' and cabane struts done. Did you carefully check the incidence levels? Initially I did not, as instructed at the beginning of the manual - BIG mistake.
I purchased two incidence meters (laser and needle-type) and spent over 20 hours with the alignments, fabricating new struts and basically confirming everything is true.
With the fuselage absolutely level, my initial readings were 3 degrees positive on the lower and 3.5 on the upper. Spec's call for 0 degrees lower and 1.5 - 2 degrees upper. In addition, the mounting deck for the horizontal platform measured 1 degree Negative!
So, I literally discarded the N-struts and built new ones with 5/32" music wire and brass tangs. To correct the cabanes, I simply shimmed them with ply - 1/8" aft and 1/32" fwd.
The fuselage required 1/8" removed from the rear saddle.
The horizontal stab deck required a tapered 1/8" shim (fwd.) to give me exactly 1.75 degrees of positive incidence on the H-stab. Measurements are now exactly as plans indicate, except for the positive incidence in the H-stab.
So, how much time do you have invested? What is your target weight with the electric power system? I'm shooting for 15.5-16 lbs. with that Saito, SolarTex, latex paint.
This week, I'll be cutting the ailerons out, hinging and installing the wing servo trays.
NICK
NICK
GA
Nick,
Are you going to add a spreader bar between the wheels? I originally didn't on my BUSA. But, after many landings the wheels spread further and further apart. I added the spreader bar and it stiffened up the gear alot.
I am working on a Proctor 28 now and they have a spreader bar. Just something to consider.
That Saito radial will surely sound sweet. Good luck with the rest of the build.
John
John
Nick
I have not yet checked the incidences and should have done so - will report back the results.
I assumed (naively?) that the kit build would take care of the incidences.
Started the kit in February and found it an easy enough build.
I noticed the lack of a spreader bar and will probably add one now, as the U/C is bound to spread with my landing skills.
I am hoping for a weight around the 12 lb mark
The tail bracing wires seem a bit OTT, so I intend using kevlar thread in place of the wires and quick links.
Using closed loop control on the rudder
Twelve pounds is a bit conservative. Maybe if AAA contest balsa was substituted for the kit wood, which I found was heavier than I'm used too. Covering?
You will likely need nose weight; however placing those batteries up front will certainly help.
NICK
I'll need to do some tests with the motor before flying.
I used balsa for the fuselage decking instead of the ply supplied to save weight and because I was having difficulty trying to shape and bend the ply.
Covering in Polyester (Polyspan?) will save a bit as well hopefully.
Great surprise! Please provide all information, including CG location, control throws, total weight (RTF) and overall flying characteristics.
I'm awaiting rib stitching before I can cover. Ordered the roundel stencils for painting; just didn't feel comfortable with applied decals or graphics over the stitching and open-bay design.
NICK
NICK
The weight for the first flight was under 12 lbs.
The CG was about 3/16 in front of the plan mark, and I set the control throws as per instructions and they seemed just about right.
The model flies great with no apparent vices - just like a big trainer, although I just flew it around and have not yet tried any aerobatics.
I'll now need to think about painting and finishing it.
For stencils try getstencils.com Great guy to work with..
http://www.getstencils.com/
A picture of my SE5a using his stencils.
BobH wrote ...
Mike
I received my roundel stencils from Gary last week; they look great.
I'm about one week out from completing the covering which is taking longer due to the rib-stitching.
NICK
NICK
Very nice - how much does she weigh?
Poasted a video of mine flying here (I need to do something about the background noise on the video !!)
http://www.youtube.com/watch?v=7cCy4oRA5tU
